Page 40 of 42 FirstFirst ... 30313233343536373839404142 LastLast
Results 391 to 400 of 418
Thread: USB FM RDS Solution with sofware
  1. #391
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    It should also be noted that the Brando USB Radio(cheaper than the Silabs) is actually just the Silabs module in a different case and with an aerial as discussed in this thread.
    I'll also help test this new .dll as the main problem I've been having is the sounds not cutting off when changine between radio and media in CF
    I installed my carpc into my pet Kangaroo, mate.
  2. #392
    Nov 2007
    Currently we are working on a new version so please hold on for a day or two before testing.
    If you don't use resume you'll be fine with the original plugin I think. But you should hear noise after you've been using the radio.
  3. #393
    Dec 2005
    Sydney
    hey guys,
    i've been playing with my skins lately and now i've stuffed up my presets list somehow. I'm using the simplistique skin, can any1 tell me what i need to look for to get the presets to work? everytime i add one via the skin the list is blank the next time i getback to it
  4. #394
    Newbie petb's Avatar
    Nov 2007
    What i think is wierd is that when you attach a external antenna the recieption only gets good just like a original radio.
    could it be that the pc is the bottleneck because it cannot transfer the radio signal fast enough to the usb radio adapter while the cars is moving?..
  5. #395
    Dec 2006
    India
    Quote Originally Posted by petb View Post
    The behavior of the USB radio when you connect an external antenna should not be any different from your original radio since the RF front-end and hence the sensitivity is more or less the same. The sensitivity may be even worse for a USB radio but it all depends on the hardware implementation of the front-end RF amp/pre-amp.
  6. #396
    Sep 2006
    Cornwall, England
    Angry
    I would like to know if anyone has had a problem with the USB radio. mine worked fine for about two months, then the computer kept making the 'USB device connected/disconnected' sound and now all I have is an orange LED on the USB radio and the computer will not recognize it.
    I emailed Silabs about my problem, and they replied.....
    Hello,
    Sorry for the delay in answering your email. The problem you are seeing is probably due to flash corruption which means that the contents of the flash has been accidentally modified. In this case you should reflash the device.
    To upload again the flash with the correct firmware you will have to do the following:
    1. download the latest version of the FM Radio RD firmware from our website:
    http://www.silabs.com/tgwWebApp/publ...USBFMRadio.htm
    2. connect to the USB FM Radio (you need an USB Debug Adapter for this):
    - on the debug adapter's connector, the pin 1 is the one corresponding to the red wire or to the arrow on the connector
    - take the FM Radio board out of its casing
    - near the MCU are three holes which are the GND (written next to it C12), C2CLK (written R18) and C2DAT (written C17). These holes can be used to connect to the device using the debug adapter as follows
    - connect pin 9 of the Debug adapter to GND (hole with C12)
    - connect pin 7 of the debug adapter to C2CLK (hole with R18)
    - connect pin 4 of the debug adapter to C2DAT (hole with C17)
    3. connect the USB FM radio to the USB port and the USB Debug Adapter to another USB port
    4. open the silabs ide and press the connect button. The device should get connected
    5. extract the zip file you have downloaded
    6. open the F320_FM_Radio.wsp project with the silabs ide
    7. compile the project and download it to the device.
    8. disconnect all wires and everything should be working properly
    You will need the full keil compiler to compile this project since it is bigger than the standard 2K. In case you do not have the full keil compiler, I have attached the compiled hex file which can be uploaded to the MCU as is.
    Please let us know if you have further questions.
    So I have to buy more stuff from them to reflash a product that I bought from them and stopped working! Surely this can't be?
    Anyone else had to do this?
  7. #397
    Nov 2006
    The Silabs module isn't a 'consumer product' so to speak. It's more of a demonstration of the hardware produced by Silabs that is used by resellers etc.
  8. #398
    Oct 2007
    I can't get my silabs to work good in my car, probably because the car antenna is powered.. If I plug the connector from the silabs to the car antenna it work intermittent, if I unpluggit and try with a simple wire 30cm long work but no very good signal.. so I think the problem is the car antenna..
    How can I know id is a powered antenna?
    If is powered how can i connect my silabs to it??
    My car is New Hyundai santa fe.
  9. #399
    Sep 2006
    Cornwall, England
    After a few more e-mails to Silib Labs and a few tests carried out on my USB radio, they found that it is a fault with the device and are going to send me a new one. Can't wait to try it in the van.
    trinky2000, when you say 'powered' do you mean with an amplifier, because every car ariel that I know that is called 'powered' simply means that it is a telescopic ariel which can be powered up and down by the ignition or radio.
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
  10. #400
    Oct 2007
    Quote Originally Posted by portreathbeach View Post
    I mean amplified...
    Any way something strange happened..
    I've the cable an the shield soldered to the silabs and I've a connector female connected to the car antenna male connector...
    I connected a simple 1 meter wire to the shield by the hole on the plastic of the silabs (a little spot was not covered), this cable is non connected to anything.. then I folded that cable and everithing and place it in the back of the monitor... Everything work great!!!
    How that could be???
    I'm still not sure if my car antenna is amplified, is a New Hyundai Santa Fe...
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  2. Not enough power to USB devices >> Possible Solution?
    By Tuckie in forum General Hardware Discussion
    Last Post: 11-16-2005, 11:24 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  4. FS: USB TV / FM Tuner, haupauge usbtv
    By e36mp3 in forum Classified Archive
    Last Post: 11-18-2004, 10:03 AM
  5. USB FM solution good or crap?
    By Jake in forum General Hardware Discussion
    Last Post: 10-03-2002, 01:56 PM
