Page 20 of 80 FirstFirst ... 10111213141516171819202122232425262728293070 ... LastLast
Results 191 to 200 of 799
Thread: Renault "Tuner List" Head Unit/CD changer hacking - Controls
  1. #191
    Apr 2005
    Belgium
    Quote Originally Posted by Vicne
    Maybe my schema is ambiguous regarding pin numbering as it depends whether you look "at" or "through" the connector. Numbering refers to the one of pinout below.
    I just came across that topic with a picture of the back of an "Update List" HU and the connectors are not arranged the same way as on the "Tuner List". Are you sure of the pin numbering there ? On the "Tuner List", the plastic tab to unlock the connector next to pin 18 is on the right (when looking at the HU from the front), and I wonder if the connector is not rotated 180° on the "Update List"...
    Maybe you should check with a voltmeter which pin is at 12V while the HU is OFF : that is pin 16.
  2. #192
    Apr 2005
    Belgium
    Quote Originally Posted by pippolippi
    So, since by connecting pin 14 to my rs232 port the led lights up, either my HU is wacky or there's a pull up resistor on the HU input.
    Could you try the test I suggested on post #183?
    Well, I don't have the scope anymore.
    If it's not a reversed plug, I can try to borrow it again indeed, although the test by CristianC and Mox's description of the Connects2 make me think more and more that it's voltage based.
  3. #193
    Feb 2006
    If the question is for me, the answer is: yes I'm sure, since I have the same model as you
  4. #194
    Variable Bitrate slimmegane's Avatar
    Feb 2005
    Italy/Lecce
    Here my HU, Megane 2 - 2003 -
    How I can help you? Excluding logging?
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
  5. #195
    Feb 2005
    Italy/Lecce
    Can I be of help trying something? Me however I don't have the cd chargher. But I am very practical with the printed circuits and the pc.
  6. #196
    Apr 2005
    Belgium
    Quote Originally Posted by slimmegane
    Then I think we're all aiming at the first emulator, but the only one of us who has tried (Pippolippi) didn't have any result until now. If you have an oscilloscope, it would be interesting to see if you get something out of pin 13 of the blue connector when powering up the HU...
  7. #197
    Apr 2005
    Belgium
    Current spy circuit
    As the last version was rather outdated, here's the current version I'm using to log the protocol.
  8. #198
    Apr 2005
    Belgium
    Proposed emulation circuit
    Here's what I'd like to propose as a bidirectional circuit. It's only using Op Amps as comparators, with a feedback to create an hysteresis of 12V x 1K / 5.8K = 2V. The 10K variable resistors should allow to adjust the threshold to the correct level. On the PC > HU side (right), I'd set it around 1/4 to get a 3V threshold and on the HU > PC side (left), I'd set it around 1/2 to get 6V.
    As long as the PC port considers the lowest output of the LM as a RS232 "negative" voltage, it should work, I think...
    Can anyone comment on this ?
    ***EDIT : CIRCUIT REMOVED. Probably wouldn't work due to negative voltage. A working circuit is available in post 245***
    Feb 2006
    1. from the 232 to the HU I think that you could safely leave the threshold at 0 (i.e. connect pin 9 directly to ground)
    2. for the other threshold either it's not critical or if it turns out to be you need a stabilized reference, I don't know where you're going to take the 12v but I doubt that if they come from the car battery they're stable
    3. the bridges 1-6-4 and 7-8 in the rs232 connecor are unnecessary, after all you're writing your own software so you can ignore those signals. Connecting 2, 3 and 5 is enough (probably using one of 6-DSR or 8-CTS for the remote signal)
  10. #200
    Ale
    Ale is offline
    Feb 2006
    Italy
    It's ok for the side HUTX -> PCRX only if HUTX isn't an open collector, becouse with an open line the output level is unknown (can be 0 or +12v).
    For the side PCTX-> HURX i'am not sure it will work becouse when the tx line goes negative with the resistor divider 1K-5.8K the input V- of opamp will be exposed to a negative voltage causing a malfunctioning of the output. (from datasheet Note 6: This input current will only exist when the voltage at any of the input leads is driven negative. It is due to the collector-base junction of the input PNP
    transistors becoming forward biased and thereby acting as input diode clamps. In addition to this diode action, there is also lateral NPN parasitic transistor action on the IC chip. This transistor action can cause the output voltages of the op amps to go to the V+voltage level (or to ground for a large overdrive) for the time duration
    that an input is driven negative. This is not destructive and normal output states will re-establish when the input voltage, which was negative, again returns to a value greater than −0.3V.)
