Page 55 of 81 FirstFirst ... 5454647484950515253545556575859606162636465 ... LastLast
Results 541 to 550 of 801
Thread: Renault "Tuner List" Head Unit/CD changer hacking - Controls
  1. #541
    Newbie Graf's Avatar
    May 2006
    Quote:
    Just one more question. Are the signal ground for D2B and common car ground connected together or not.
    I wouldn't assume that. If you can, opto isolation is always safer I think.
    I agree about opto isolation between PC and CAR but my question was about CAR GND and TX-RX-GND part, becouse 12V from REMOTE HU is used for pull up voltage for transistor, but if there is some kind of isolation between CAR GND and TX-RX-GND for D2B it will not work, tomorow i will take out HU and measure resistance betweeen HU GND and HU TX-RX-GND
    I have pins on 10 pins ISO connector style on HU.
    I am at the moment in stage of collecting peaces and i will probably make first testing on weekend.
    Thanks for help Vince
  2. #542
    May 2006
    radiosat 6000 layout
    here is a pin layout of radiosat 6010
  3. #543
    Jun 2004
    how to emulate display info in carputer like virtual display
    hu info displaj to carputer...
    i have i2c interface
  4. #544
    Apr 2005
    Belgium
    Quote Originally Posted by NOKIALKATEL
    I guess your question isn't particularly related to Renault cars, Tuner List head units and CD changer emulators, right ?
    In this case, I would kindly advise you to use the search menu of the forum and look for "I2C display" or something like that for more appropriate threads.
    In case you don't find any result, don't hesitate to start a new thread but please be more precise : What are you missing ? Hardware interface ? Software driver for the I2C display ? Plug-in for Winamp or a Front-end ? Is the I2C display part of your car or is it a stand-alone display ? Make ? Model ? The more details you give, the higher the chances you'll get a useful answer .
    Good luck.
  5. #545
    Apr 2005
    Belgium
    Quote Originally Posted by Graf
    Wooh... Looks like it doesn't have much in common with what we know.
    The most worrying part I think is that pin 2 is labelled "CD Changer communication data link (+), data" and 3 the same with "(-)" and "!data".
    Unless the guy who wrote this sheet had fun changing the labels to look more cool, it looks more like a balanced signal than a Rx/Tx pair
    Moreover, as there is no information regarding direction, I guess it's a bus type of communication...
    In this case, all has to be started again from scratch and hardware part won't be that easy I'm afraid...
    Do other members share the same feeling?
  6. #546
    Jun 2004
    faceplate software emulateheadunit with remov.faceplate,
    now=headunit---->faceplate
    headunit---->software or frontend emulate interface er i2c from headunit to seriel
  7. #547
    May 2006
    Quote Originally Posted by Vicne
    yes I agree with that here below is some table list of HU and CD changers
    Megane, Laguna, Clio II Philips DC259, DC279 VDO CH-0600
    Philips (D2B) DC459, DC461, DC594/62L, DC459/62L Philips D2B
    SAT6000, SAT6010
    it is definitely D2B bus, which means that it needs TX-RX to bus interface or
    try and se what happens
  8. #548
    May 2006
    can you share pin layout on your HU and maybe we can see some similarities
    or to rephrase question where did you find that pins on HU have TX,RX labels
    i have been browsing through various documents and did not found it till now
  9. #549
    May 2006
    thanks vicne all what you wrote is right
    is seems that d2b is bus and probably it is different protocol also
    anyway in the meantime i have developed a board for opto isolated version for TUNER LIST HU series and i will put it on the net tomorow
    it will have no use for me but it will save some time to somebody else
  10. #550
    Apr 2005
    Belgium
    The source I had is here (can't remember where I found it).
    I then compiled and illustrated pinouts for both Tuner List and Update List (with some help) on this page.
