Page 65 of 81 FirstFirst ... 15555657585960616263646566676869707172737475 ... LastLast
Results 641 to 650 of 801
Like Tree1Likes
Thread: Renault "Tuner List" Head Unit/CD changer hacking - Controls
  1. #641
    Aug 2006
    You mean pro board,emulator+SPDIF all in one?If so,please atached this picture,list of elements,program for PIC and pictures,so i can normaly make this all in one pcb and starts liostening to mp3s in my HU tuner list.
  2. #642
    Aug 2006
    So, as I said here is the complete board.
    It includes all you need.
    Remember. All you do is for your own risk. I don't take any responsibility for this!
    I've attached the schematics, top pcb design, bottom pcb design, and a picture of how it should look like And the hex file also. The hex is compiled for 16F88 @ 4 Mhz.
    You can check the schematics for the values of the parts.
    Schematics:
    Top:
    Bottom:
    How it should look:
    And the hex:
    TunerListCdc.zip
  3. #643
    Mar 2006
    Yahoo!!!
    This is amazing, thousand thanks!
    Can we have a higher resolution of the first image (the design) ?
    And can you tell me what size the pcb is supposed to have so I can print it correctly ? We're doing 4 here !
    Thanks a bundle!
  4. #644
    Aug 2006
    So here is the schematics.
    Digital0001.zip
    Protel sais that the board is 78.73951mm X 82.012mm
    But remember, if you print the board try at least 1 ic on it if it fits the size ( befor you iron and etch the board ).
    And let me know how you succseeded.
    And the 74ls04 supposted to be 74hc04. Sorry
  5. #645
    Aug 2006
    Why is there so many connectors on each side?14 on left and more on right?
    Is this PCB double sided,becouse of picture?(UP has a line or to to bypass?)
    Is the second and third picture swaped betwen,couse TOP looks to me like bottom where is no elements,and BOTTOM looks like UP where the elements must be.
  6. #646
    Aug 2006
    Quote Originally Posted by markob View Post
    the 14 connectors are on the right, not the left These are ( from down to up ) analog-stereo ( headphone in ), Ipod, ICSP. You can see the pinouts on the schematics. On the left it is the connector for the head unit. The pin 1 = 13 pin of head unit
    It is a double sided pcb. The top is top, and the elements are on the top side, as you can see the last picture.
  7. #647
    Mar 2006
    Ok I started looking online for the components, and I cannot find the Schott 22083. Do you know where to find it or what can replace it ?
    I have a friend that can print the circuit board for me, but he would like to have the design file in its original format so that if he doesn't have exactly the right components he can adapt the board, would it be possible for you to send this file ?
    Thanks a lot!
    PS: The components I have found so far seem to add up to about 65€, is it close to what you found or do I need to find a better supplier ?
  8. #648
    Aug 2006
    What 65 euro? twice as much is new mp3 player
  9. #649
    Aug 2006
    You can replace the transformer with PE-65612. Visit cirrus logics home page and look for the "Recommanded SPDIF transformers" data sheet. I'm not sure that this is the exact name but you can find in under products/cs8406.
    The price for me was ~17 euro ( excluding the board ). You deffenetly have to look somewhere else.
    The board was designed in protel 99se. The files are 17 Mbytes, so it is far too big to send by mail.
    Your friend can design it from the schematics and can modify the footprints as desired.
  10. #650
    Jun 2006
    Hi Foldesa,
    do you know if this emulator can work on before-2000(non tuner list or update list) models??
    The communication with the cd-changer should be the same, because the cd changer is the same too (a Philips RC026 renamed CDC026 after year 2000).
    My HU supports D2B communication and here are some pictures
    http://giovaland.altervista.org/gall...ryalbum&aid=75
    The only difference between the HUs is that mine accepts analog left and right channels so... I think I don't even need the spdif converter .. am I right?
    Do you have the schematics for the emulator only? How much $ do you think it should be?
    Thanks in advance,
    Giovanni.
