Page 74 of 81 FirstFirst ... 24646566676869707172737475767778798081 LastLast
Results 731 to 740 of 802
Like Tree1Likes
Thread: Renault "Tuner List" Head Unit/CD changer hacking - Controls
  1. #731
    Jan 2007
    Thx!
  2. #732
    Jan 2007
    Hello, Sorry to go slightly of subject, I've recently purchase the update list CD player to replace my tuner list, however the display and stalk controls don't work. Does anyone know why this is and is there a work around to resolve this. I have a 2002 Megane and the update list CD player came out of a 2004 Megane. Any advise would be greatly appreciated.
  3. #733
    Apr 2005
    Belgium
    Quote Originally Posted by Michal View Post
    Hi Everyone!
    I think I found another way to enable "input" in Cabasse TunerList amplituner.
    Car Radio Digital Signal Processor Philips Saa7708H used in this unit, has two digital spdif inputs. Spdif1 (pin25) is used by additional cd changer and, as we all know to eneble it we have to have cdc or an adapter. But spdif2 (pin24) is used by internal cd drive of HU, and this one input is always enabled when compact disc is inserted. So we can use the same circuit with relay like Vince used, but we don't need cdc and any cdc emulators.
    I would like to add some pictures, but I don't where is this option at this forum.
    Hey, that's smart...
    Well, of course, it probably doesn't qualify for "best no-modification solution" but if it's your car, why not ?
    I guess you could also have cut the ribbon cable and put an A/B switch or relay to be able to keep standard CD functionality at will, or are there components between the ribbon cable and the chip ?
    I guess a similar trick could be used on other models as well...
  4. #734
    Apr 2005
    Belgium
    Quote Originally Posted by ger_uk View Post
    No idea. Maybe you should turn to Renault specific forums where car dealers and experts hang around. For French-speaking forums, I'd suggest http://www.planeterenault.com
  5. #735
    Jan 2007
    Quote Originally Posted by Vicne View Post
    No worries, i guess i better start learning some French then.... Dam, i knew i should have choosen french instead of welsh in school !
  6. #736
    Jan 2007
    hi all!
    i'm surely not in the correct topic but plz show some mercy on me.. i'm goin dizzy trying to cope up with all that data i read here...
    questions now!
    part I:i need to alter the wiring of the philips hu in my laguna (phase I, face lift) so that i can install a tuner list from a clio. the thing is that philips hu as i'm sure you may know haw a long conector with 7 (?) pins whereas the clio haw a rectangular one. trying to make the connections work and combinning cables didn't give out much, i only managed to make the remote on the steering wheel work but never had any luck with the on dash screen.
    part II: i would also like to know how to "fool" my hu so that i can have an aux in for my pda to play through the car speakers.
    i'm really looking forward to hearing from you..
    kind regards
    panos kloustiniotis @ greekrenaultclub.gr
  7. #737
    Jan 2007
    Macon (France)
    Hello, First of all BRAVO, this thread is fantastic.
    I'm interrested by the cdc emulator based on a PIC microcontroler, (I just want to add an Aux Input to my Tuner list Unit). Could you just resum me at wich stage you are today. If i understand the hardware is done but the sofware is bugged. I'm electronician and driver of scenic car so may be i can help you, let me know if i'm right and what can i do?
    I think first i need to do the hardware, did you know how can i do easly the PCB because it's dual side!
    Kinds Regards
  8. #738
    Feb 2007
    Czech republic
    Pic PCB did not works
    Quote Originally Posted by Ale View Post
    Hi happy new year to All!
    Sorry for the long absence!
    Here the answer for the remaining doubts:
    F) the GP23 is a small alcaline battery of 12V that I use for programming PIC. In this circuit I use a MAx Tx driver to convert 0-5V of the LPT1 to a 0-12V signal needed by the 16F688 to enter the programming mode.
    It need at least 10.5-11V on pin MCLR(pin4) to enter programming mode, and the internal voltage doubler of MAX232 give less than 10V, so I tied the V+ pin to this battery, and the doubler capacitor C1 is not needed anymore.
    G) Sure the regulator 78L12 can be used insead of the battery without problem.
    In normal running mode the MCLR is left open, the internall pullup provide the correct +5V level.
    Bye
    Ale
    Hi ALE and all!
    so what goes on..? I have tried to make PIC-based PBC of TLCDEMU. After making board, checking bugs I try to program PIC. It work, but summary of programming was the process of programing was incorect > listing LOGs and find something like this "002008 incorrect > read 00C001 wanted 003FFF"
    So I tried to change this bug by changing in "Config memory" (winpic programmer) current item. after that I reprogrammed PIC and no bugs were found. So I connect PCB to HU but nothing was happened. No other item in Source. I think that is problem in wrong programmed PIC isn`t it?
    I have Renault megane 98 with original Philips Radiosat 6010 (22DC459/62L) with 10 pin ISO conector for CD changer.
    In this thread I found difference between DB+/DB- signals and standard BUS protocol. Could be problem here?
    So maybe I find other problem. I have not grounded signal BUS for DB+/DB-. I will try to correct it and post result.
    Thanx a lot! Supertronik
  9. #739
    Feb 2007
    Analog audio input?
    I've been looking around interent for projects like this, and this seems to be as close as I get.
    My goal would be to connect a Sony Ericsson phone to be used as MP3 player and to work with handsfree.
    I want the sound to automatically go throu the car radio whenever there is a sound coming out from the phone, and I want the volume controll of the car radio to be used.
    I looked for schematics drawings of the car radio and I thought I had most of it figured out, until I realized I was looking at the wrong model... The radio I thought I had used TDA7318 audio chip which is a digital sound process with analog audio but uses digital controls. It has a input selector and after that an output and input (for external pre amp / eq, etc) and then volume etc and amplifier. This would be very easy to just use the "EQ throu" and just override the signal before volume controll etc...
    However, I realized the radio I actually have is a 22DC279/62F (Philips Renault Tuner List) wich uses SAA708H Audio processor, which is a fully digital processor, which makes things harder.
    Anyway, maybe it will work out anyway. On the chip there is a CD input and a Tape input that is not used (internal CD uses PDIF). There is also a Phone input, but only mono.
    The CD input could be used for this. My "only" problem is that I'm not the very best when it comes to microprocessor programming, which makes things a bit complicated nowadays when everything is digital...
    So what I need is a PIC (or similar) that has just one input. When the input is 1 the car radio will swith to CD input (and preferrably show AUX in display), and when the input is 0 the car radio will go back to where it was before.
    I could use the "connects2 box", but as far as I understand I will then have to change source to "CD-Changer" whenever someone calls... I want it to automatically over ride all inputs so I don't have to press anything.
    The analogue design is no problem at all for me, and I will post it here if I design it. But first I need the digital part figured out...
    Can someone help me, please?
    (I can send you data sheet for SA7708 if needed, I can't attach it due to file size limitations in this forum)
    Thanks for a very good forum!
  10. #740
    Mar 2007
    Newby renault / radiosat question?
    Do you top minds out there know if I can hack the basic (brand new radiosat update list) HU unit in my Grand Scenic so I can play MP3 CDs. You know a bit like changing your single region DVD player to multiregion via pressing a few buttons in the correct order. I can't believe the technology isn't already in it???? It does however have an auxiliary input, but I don't want to spend out if I don't have to! Any advice greatly recieved
    cheers in advance Soundbored...
