Page 75 of 81 FirstFirst ... 256566676869707172737475767778798081 LastLast
Results 741 to 750 of 802
Like Tree1Likes
Thread: Renault "Tuner List" Head Unit/CD changer hacking - Controls
  1. #741
    Constant Bitrate Putput's Avatar
    Sep 2005
    Belgium
    Quote Originally Posted by soundbored View Post
    Do you top minds out there know if I can hack the basic (brand new radiosat update list) HU unit in my Grand Scenic so I can play MP3 CDs. You know a bit like changing your single region DVD player to multiregion via pressing a few buttons in the correct order. I can't believe the technology isn't already in it???? It does however have an auxiliary input, but I don't want to spend out if I don't have to! Any advice greatly recieved
    cheers in advance Soundbored...
    Hi,
    Look here on post #458, you can find a pdf with all the info you need to connect the AUX input from your Update List HU. But be carefull, the input is versy sensitive and easily damaged. I suggest that you use 2 100nF condensators to protect the input.
    Putput
  2. #742
    Mar 2007
    Thankyou for your input, so how does the 100nf condensator thing work, mini iso to left and right with inline 100nf in each?
    Any thoughts on the HU already having the gubbins inside to read mp3 cds, the manual shows the same unit capable of mp3 playback. I reckon it just needs switching on!
  3. #743
    Sep 2005
    Belgium
    If your manual talks about MP3 then you might be right and the thing just needs to be switched on. I could not find anything about MP3 in my manual so it appears to me that you have a different Update List type. I posted a picture in the beginning of this thread where the type is shown, you can check this if you want. If you want to give it a try, a simple drawing is attached on how to connect the 100nF condensers.
  4. #744
    pcp
    pcp is offline
    Mar 2007
    Hi everybody,
    I read my way through the thread and the Sourceforge page. So I gather that to date, nobody has developed a working solution for the older Renault/ Philips head units, right? Pin out I found, but no protocol description. anywhere on the web, actually.
    What protocol do the Tuner/ update list models use? Is that wildly different?
    Any users who have had a shot at the Renault Radiosat 60x0/ D2B with some success?
    I just got a Megane with a D2B unit and no cd changer.
    I'm an E.E. myself, so if someone can tell me what the HU/ changer say to each other, I can build the rest. Or if anyone is based in the UK and has both HU and changer, I can come by with a 'scope and log it myself.
    Buying a changer off ebay is too expensive (because I want the aux port, not a cd changer), might as well get a new radio w/ aux in.
    Thanks for your advice!
    PCP
  5. #745
    Apr 2005
    Belgium
    Hi, PCP,
    Quote Originally Posted by pcp View Post
    Right. Only newer Tuner List models work for sure.
    Not that I know of, unfortunately. As for the difference, I really have no idea.
    I think it's the only way to know for sure, indeed. There are many people who have expressed interest in such a solution, but to date nobody has been able to reverse engineer the way those older CDCs work.
    As for cheap second-hand CD Changers, I was thinking maybe in wrecked cars ...
  6. #746
    Mar 2007
    Denmark
    Quote Originally Posted by Vicne View Post
    What has to be done :
    - hardware connection of control wires to the PC. The pinout is available in this post and as I said there :
    among the protocols listed on ۝ Mictronics - Michael's Electronic Projects ۝ , the only one that uses asynchronous two wires transfer (RX + TX + no clock) is the Blaupunkt one. Moreover it uses the same wires as our Tuner List, so that's encouraging : compare the last page of http://www.blaupunktusa.com/NR/rdonl...5E/0/MDP01.pdf to the attached pinout of the Tuner List. I also had confirmation by bistie on planeterenault.com forums that once the levels are adapted (5V TTL to 12V RS232) the protocol is compatible with a PC serial port.
    Hi Vicne.. are you thereby suggesting that the protocol used by blaupunkt and by the OE renault equipment is the same, or are you merely saying, that they are both async protocols???
    (im currently working on a project to fool my blaupunkt hu, which incidentally is mounted in a renault :-)
  7. #747
    pcp
    pcp is offline
    Mar 2007
    Thanks for the info. I'll try and see what I can find out. Will post if I make progress.
    If anyone is interested in this and has a D2B / Radiosat 60x0 together with a CD changer, please get in touch with me!
  8. #748
    Apr 2005
    Belgium
    Quote Originally Posted by hooverphonique View Post
    I'm only speculating. To be clear, I have *no* idea. I just noticed some similarities...
  9. #749
    Mar 2007
    Denmark
    this is slightly off-topic, but since someone mentioned it in this thread already, i'll ask anyway..
    does anyone here have a schematic over the renault stalk remote control? the switches are connected in a matrix somehow, but i can't seem to get the right configuration when measuring..
    the car is a renault 19 btw.. the stalk rc has 4 buttons and a wheel on it..
  10. #750
    Mar 2007
    Denmark
    nm.. it works now... colors are the individual wires at the connector and S5 is the wheel (works like a rotary encoder, one switch closed at a time)
