Page 78 of 81 FirstFirst ... 286869707172737475767778798081 LastLast
Results 771 to 780 of 801
Thread: Renault "Tuner List" Head Unit/CD changer hacking - Controls
  1. #771
    Jan 2008
    Alright then, got a new radio, did the same job on it, same result, no matter what switch position, I hear the cd playing. But I eventually found out why
    Quote Originally Posted by Vicne View Post
    3rd possibility : a problem in your setup. Are you sure your switch is OK ?
    4th possibility : OK, you hear the CD playing when the wire is cut and hanging in the air in high impedance, but what if you ground it (via a resistor to reduce the risk) ?
    It's a bit of both a think I have massive crosstalk in both of the two switches I tried. If the wire is actually hanging in the air sound is dead as it should be, but if I get near the other wire 1 or 2 mm I already hear the music
    So I just cut it and connected my PC and SPDIF-In works like described by michal
    So I just have to find another switch, maybe two on/off switches far away from each other
    edit: alright, if anyone wants to do it this way once, inside put one cable on the one side of the radio and on on the other, otherwise the cd signal will find its way somewhere ^^
  2. #772
    Jan 2008
    Hello, I wrote from Spain,
    I am new in this forum that I have found looking for like solving my problem with the "Cabasse UpdateList" of my Renault Laguna.
    My problem is that I have activated the auxiliary entrance, with pins 10.11 and 12 of the C2 connector, and has worked perfectly during days, but now the sound is listened to very distorted, I have proven to connect CarPC, a MP3, a PocketPC and everything is listened to bad.
    If I cannot repair it, the following possibility that I have is to connect entrance SPDIF with the CarPC. My UpdateList does not have cd charger that is to say, the C3 connector is right now without using, that it would have to make to use the SPDIF?
    This is my unit:
    Best Regards
  3. #773
    Apr 2005
    Belgium
    Quote Originally Posted by holodoc View Post
    Yes, that's what I meant by my 4th possibility. If you leave the input wire hanging without any actual source, it acts as an antenna. Not an expert in SPDIF, but even ignoring the control bits, the frequency is at least 16 bits x 2 (stereo) x 44.1 kHz = 1.4 MHz, so capacitive coupling should not be underestimated.
    Well, I think if you feed the input with an actual source, it should end the crosstalk because the input voltage will be forced by the source...
  4. #774
    Jul 2006
    I finally found the problem with the circuit
    I was missing a capacitor that made the +5v to the µP to ripple so the HU didn't recognize it . Also my SPDIF optical to electrical converter works perfect.
    I have added the copper layout as a pdf.
    // lond
  5. #775
    Mar 2008
    Question Renault Carminat SH1 Connector x Modus
    Can you help me find aux pin on Renault Carminat SH1 Connector x Modus?
    Thanks in advance
  6. #776
    Aug 2006
    Hi all,
    I am new in this topic. I am interested in the PIC based CD charger emulator but I am having a hard time finding the info I need in this very long topic.
    in http://tlcdcemu.sourceforge.net/pic.html the Max232 is only used for programming reason, am I right? If I have a PIC programmer I do not need the MAX232?
    Where can I get the file that needs to be loaded in the PIC?
    Thank you in advance.
  7. #777
    Apr 2008
    Hi all
    i read the all thread but doesn't find these info, hope you can help me.
    i have a scenic of february 2004 with a tuner list
    i find an update list and try to connect... the radio response to eject and probably ask code but the display doesn't work
    i know this should be a different pin connector between old and new model (this for what i read around the web is due to the old radio was manufactered by philips, new one by blaukpunt)
    due this i find on the net some pin connection scheme but for old models....
    http://tlcdcemu.sourceforge.net/hardware.html
    as i read here "Warning : This pinout is for Philips/VDO/Dayton "Tuner List" and "Update List" head units only. Other models (i.e. Blaupunkt) are known to use the same physical connectors but with a different pin assignment."
    does anyone here have new blaukpunt scheme connection?
    is this translation possible or the new model use different codes to trasmit info to the display and steel whering controls?
    please help
    tnx in advance
    ale
  8. #778
    Jul 2007
    Quote Originally Posted by didier_26 View Post
    Hi all,
    Yes. But you need make signal from HU - Tx (pin 13) on discrete component. You can get part from simple version adapter (http://tlcdcemu.sourceforge.net/hardware.html) - like as signal Tx (pin 3).
    http://sourceforge.net/project/showf...roup_id=161294
    You need tlpicemu.zip on this page.
  9. #779
    Jul 2007
    dont suppose anyone has an explanation/ diagram of what pins on the face pannel do/control, i'm trying to hack the front pannel to control some parts for my car pc
    Baz
  10. #780
    Aug 2006
    Please help me...
    i get CD error mesage on headunit...
    I bought CD renault orginal cd player head unit y2001.I put it in to megan y2000 instead old cassete player headunit, everything works(tuner,display,stearing control) even CD, but the problem is when i insert CD(original or pirate) headunit read how many tracks are on cd and begin to play at first cca 5 sec i can skip track how ever i want, but when i started to listen track i get CD ERR message, cd plays normaly but i cannot change track ,i can only do that at first cca 5 sec, if a go back on tuner, and back to CD i have new cca 5 sec to change track.
    What is that error mesage and what is the problem?
