Results 1 to 10 of 20
Thread: Quadrature Decoder
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    Quadrature Decoder
    Okay, so, I have bought one of the ALPS encoders, and I'm working with it to build a controller for my car PC.
    The problem I'm having is, the rotary part of the ALPS encoder puts out a "quadrature" signal (yes, I know most of you already know this), but I need a more-or-less binary signal. I.E. Encoder has moved one position forward or Encoder has moved one position backward.
    I know a lot of you are using scroll mice to accomplish this, but I'd really like to use it with another device I picked up from a gaming site.
    Is there an IC out there that will translate the quadrature signal from the encoder, and just output pulses on one of two pins? Or should I just abandon that idea, and just use a mouse like everyone else?
    I've found lots of stuff online relating to this, but nothing that seems to solve the problem directly. One link in particular that might answer the question is this.
    Unfortunately, being a software engineer, and not a hardware/electrical engineer, I'm having a hard time understanding what's being said there.
    Any thoughts/help?
    Thanks!
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    First thought was that you could use a PIC (or similar micro) to perform the translation.
    While that would certainly work, the link you provided seems much simpler. The little D/Q boxes are flip flops - The Q (the output) latches to D's (the input) logic state on a clock signal. The arrow-ish symbols or XOR gates. If you're a programmer, at this point you can probably work your way though the logic
    You should be able to build the whole thing with 2 ICs (one for the flip flops and one for the XOR gates).
    Apr 2005
    Southern Califorina
    Okay, I think it's starting to make some sense.
    Using that circuit then, the "counter_direction" would be high for one direction, and low for another, and the "counter_enable" would pulse with each phase change of the encoder?
    I suppose I could cobble together a breadboard and try this myself, but I'd like to try to understand it first. :-)
    Check out my blog.
    Aug 2004
    SE Michigan
    Quote Originally Posted by cherrybomb
    That's what it looks like.
    Bah, build first ask questions later! (well, ok, I wouldn't normally advocate that, but given the components involved here is probably about $3 total, you might as well)
    Apr 2005
    Southern Califorina
    Quote Originally Posted by mushin
    That's what I'm thinking
    I'll go pick up some parts tomorrow and let you know how it turns out!
    Thanks for the second opinion.
    Check out my blog.
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Try these out:
    http://www.usdigital.com/products/ls7183-ls7184/
    I've used the LS7183 before and it was very easy to work with... fairly cheap too. The LS7183 pulses seperate UP and DOWN pins. Or, the LS7184 pulses a CLOCK line with a separate UP/^DOWN (direction) pin. Another plus is you can configure it to pulse once per full cycle, half cycle, or quarter cycle. You can also set the pulse width.
    When I wired up my encoder (originally... I use a hacked mouse now), I wired the output to a quad analog switch (MM74HC4316N). I connect two of these "switches" to my keyboard matrix so they would register as keypresses. Of course, you are free to whatever with the outputs.
    Apr 2005
    Southern Califorina
    Quote Originally Posted by TheLlama
    Try these out:
    Excellent!
    This looks like EXACTLY what I'm after.
    It looks like I'll only be able to order this directly from them?
    I don't see the IC available at radioshack, or marvac, which are the only local shops.
    Trying to put together a component list for all of this.
    Thanks VERY much for the pointer. :-D
    Check out my blog.
    Jul 2004
    All over the world
    Excellent!
    I forget where I got mine, I think I purchased it direct. If not, I got it from mouser electronics. I have a spare chip (the LS7183), I suppose I could sell it to you. PM me if you are interested.
    Apr 2005
    Southern Califorina
    Not a problem, I just ordered up a couple direct. Looks like that's the only place you can get them. Mouser didn't carry them.
    Check out my blog.
    Aug 2004
    SE Michigan
    That looks nice, I'll have to remember it if (when ) I need something like that.
    I always forget how many special purpose ICs are out there. God bless the electronics industry
  1. Sherwood Car DTS CIrcle Surround Decoder X-DTS80
    By millerbc in forum Classified Archive
    Last Post: 02-19-2005, 01:41 PM
  2. Which DVD decoder
    By n8scstm in forum FrodoPlayer
    Last Post: 01-03-2005, 01:16 PM
  3. Where To Put DVD Decoder?
    By nFiniteTuning in forum XP MCE
    Last Post: 11-04-2004, 12:17 PM
  4. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  5. Need small DTS decoder
    By MSUC5Vette in forum General Hardware Discussion
    Last Post: 04-04-2004, 03:39 PM
