Results 1 to 3 of 3
Thread: Dual function headunit
    Newbie CNDaccent's Avatar
    Aug 2004
    Canada, eh
    I'm currently installing my 2nd carputer, this time going for a stealth approach. I've removed the factory headunit to take advantage of a large cavity in the dash. I'm building a nice padded shelf in there to hide the LCD when not in use. The LCD mounts closer to the floor on a post. The original plan was to rewire some of the factory buttons to power down the PC, amplifier, etc while using faceplate as a cover for the LCD storage area. However, after reading about FM PCI recievers, and how crappy the sound and software is, I'm going to keep using the (relocated) factory HU.
    Has anyone tried using a relocated faceplate for more than one function? I plan on using a function selection switch to route the outputs the the correct unit i.e. HU power turns on radio or PC.
    Worklog and website are in the works.
    look at all the magic smoke...
    Small Amp, Big Car
    8" LCD
    PC and assorted parts
    Variable Bitrate DaveB's Avatar
    Mar 2004
    CND,
    Have you sucessfully extended your faceplate via CAT 5 or other cables yet? If so and if it's working please post the brand and model number of your HU.
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Jan 2006
    New York
    would be rediculous if its possible
    I was thinking of doing something similar, running the faceplate as a controller for just my computer, to control the hu i think you would need to have all the buttons wired to the pc and then have selected ones output to the hu fromt he pc otherwise you will click one button the plate and then something will happen with both ur hu and pc simultaneously instead of the button affecting only the desired unit.
    Does anyone know of some easy software that can be used to capture events from a button click if u hard wired it via usb or serial?
  1. Autodimming monitor after 2 seconds of inactivity. (Solution inside)
    By justintime in forum Software & Software Development
    Last Post: 02-01-2006, 02:48 AM
  2. New browsing function
    By TheUni in forum Road Runner
    Last Post: 10-15-2005, 12:03 PM
  3. radio receipt headunit
    By Tijs67 in forum Car Audio
    Last Post: 07-22-2005, 08:05 AM
  4. Replies: 9
    Last Post: 12-09-2004, 01:34 AM
  5. Dual monitor set up and function?
    By dogger in forum Newbie
    Last Post: 10-09-2004, 08:58 PM
