Results 21 to 30 of 33
Thread: tapping tachometer wire?
  1. #21
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by MatrixPC
    hummmmmm, I thought tach signal is AC instead of DC.
    At least my Supra is.
    To my tach indicator, it's a 5v pulsed signal (4 pulse per revolution).
  2. #22
    Constant Bitrate DrStein99's Avatar
    May 2004
    Audubon, NJ
    Quote Originally Posted by shotgunefx
    Where EXACTLY is the best place for me to hunt down that wire - do you have a 1995 maxima also? Where did you tap your wire at - please? That is the one I am looking for.
    www.RAIDGEAR.net Engineering :: Research, Development and Art - all is one www.DrStein99.com
  3. #23
    Apr 2005
    Boston, MA
    Quote Originally Posted by DrStein99
    No idea on your car. I've got a 02 Sebring Coupe.
    That's why I was suggesting you get the service manuals. I've got just about every piece of documentation for my car that was ever made.
    A quick scan of ebay finds one on ebay for your car for $7 dollars.
    http://cgi.ebay.com/ebaymotors/1995-...spagenameZWD1V
    If I were you, I wouldn't think of screwing with things until you have the docs, but that's just me.
  4. #24
    May 2004
    Audubon, NJ
    Good idea. Thanks for the link, the info looks like its worth the whole $7 and free shipping. For as often as I expect to dig around, I'm sure i'll find a use for something else in that book.
  5. #25
    May 2004
    Audubon, NJ
    shotgunefx - what language are you programming you pic-chips in?
  6. #26
    May 2004
    Audubon, NJ
    ac
    If it's ac or dc, I can check w/ an ohm-meter, and use a bridge or some other type of circuit to convert to a dc-signal.
  7. #27
    Apr 2005
    Boston, MA
    The free version of HI-Tech C.
    http://www.htsoft.com/products/PICClite.php
  8. #28
    May 2004
    Audubon, NJ
    Ok. Yes; I couldnt try that compiler - since I started with pic16f84's and now using pic16f628 chips. That compiler didnt support my chips.
    I dont have a use for the 28 or 40 pin chips yet, but have a project comming up where i need like 20 i/o channels - and was on the prowl for good and cheap developer board for that, hopefully with a zif socket this time.
    Its hard to find support for pic projects, mostly I see assembler code, which is too much for me to learn right now. I'm using sourceboost-c compiler, which the examples are mainly written for "C2C" and translating just one line can hang me up for weeks, figuring this out; its probably the most difficult project I had taken on in a long time.
  9. #29
    Apr 2005
    Boston, MA
    I think there are other truely free ones. Is the 627 that different from the 628? Might be able to compile it to asm then load it.
  10. #30
    May 2004
    Audubon, NJ
    I can use souceboost compiler now; and dont have a problem with that - just that the site / forums are very light and dont see much traffic.
    Was looking to scout around for a compiler or forum that had some more activity.
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 10:10 AM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 12:38 PM
  3. Morex 60W car kit - 4 or 6 wire?
    By MVShibui in forum Power Supplies
    Last Post: 05-09-2005, 01:28 PM
  4. Replies: 37
    Last Post: 05-17-2004, 07:01 PM
  5. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 10:58 PM
