Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: tapping tachometer wire?
    Constant Bitrate DrStein99's Avatar
    May 2004
    Audubon, NJ
    Does anyone know where to find the wire assignments for the harness in the dash-board / steering column? I know there has to be a website, or chart somewhere, I dont have any luck finding it.
    I have a 1995 Nissan Maxima, trying to find the tachometer lead - it should be a wire that delivers a +12v pulse, each engine rev.
    I'm trying to build some neat gadgets using pic/eProm software, that gathers info from the car; and I want to capture the RPM's - if possible.
    Please advise.
    www.RAIDGEAR.net Engineering :: Research, Development and Art - all is one www.DrStein99.com
    Dec 2005
    Long Island, NY
    Tachometer- white/green (ECM)
    NISSAN, MAXIMA, 1995, Tachometer
    The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left.
    Newbie Mercury_Vapors's Avatar
    Jan 2006
    Ontario, Canada
    I dont know if you'll get much out of it.. the tach wire is just a wire that sends pulses of DC current to the injectors.. i'm not sure if it changes when it goes through the firewall and connects to the ecm.. just my 2 cents.
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    why not try making your own tacho pick-up, need a sender on the engine and receiver to count the pulse.
    http://www.niksula.cs.hut.fi/~mdobru...cho/tacho.html
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Here you go. Let me know if you need any other help.Name:  diagram.jpg
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by DrStein99
    Please advise.
    I'm doing something similar for my own front end. I'm going to tap off the rpm/tach and indicators, read them with a PIC16877a and send them serially to the pc.
    If at all possible, try and hit ebay for the service manuals for your car. I've found them to be invaluable.
    Apr 2005
    Boston, MA
    Quote Originally Posted by fixerofallthing
    Negative (-) side of the ignition coil.
    I think you'll have problems with reading it from there with a PIC or other mcu. It's very noisy, electrically.
    May 2004
    Audubon, NJ
    Quote Originally Posted by snova031
    There are about 3 black panels, all the center of my maxima, and I dont recall any on the passenger side.
    Am I looking in the hump (floor) or the one facing forward - the dashboard?
    May 2005
    Lawrenceville GA
    Quote Originally Posted by shotgunefx
    You are right. That particular car is coil on plug though, so there are 6 coils. So my first response was incorrect. I posted a pic of the wiring diagram for that vehicle and the wire mentioned above is correct. It will be a very "clean" signal because it is produced by a control module for the express purpose of running the tachometer.
    May 2005
    Lawrenceville GA
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  3. Morex 60W car kit - 4 or 6 wire?
    By MVShibui in forum Power Supplies
    Last Post: 05-09-2005, 02:28 PM
  4. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
  5. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 11:58 PM
