Results 1 to 7 of 7
Thread: 2 way remove control system
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Exclamation 2 way remove control system
    To way remote control
    It’s a idea that I have work with the last ½ year, most of the circuit have be test
    The 2 way transmitter/receiver system works as a duplex connection, so the system can receive and transmit at the same time.
    The remote control is in sleep mode the most off the time to save power only wake op when key press or receive data.
    All the part in the system is power off if part not in working mode to save power.
    The big trouble now is that all the stuff was in the company I work in, an New Year night it burn down to the ground
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by 4u2n
    What does it do?
    Michael
    Variable Bitrate numbers's Avatar
    May 2005
    What processor are you using?
    May 2004
    Denmark
    Quote Originally Posted by numbers
    I use PICAXE processor, easy to use
    Becaue
    Easy to use
    Easy to program
    Every one can make program for it
    It only cost 2-6$
    it will be it better for open source
    Ditail at 4u2n.dk
    Here
    May 2004
    Denmark
    Quote Originally Posted by Wiredwrx
    What does it do?
    Michael
    the plan is to make som remote to car and you can get some status from the as (alarm, open door, temp. ...)
    the circuit is build with 200m transmitter buth it possible to get transmitter for op to 10 Km
    Ditail at 4u2n.dk
    Here
    May 2005
    Becaue
    Easy to use
    Easy to program
    It only cost 2-6$
    In that case, can you share the code you have so far?
    May 2004
    Denmark
    It’s the big problem
    I have wrote before every thing is lost on the fire New Year night in my company
    All diagram, code and the part was in the company and there is nothing bag, only the idea
    What happen now is that I need to start from the beginning again with bye all part and the start program it all over again.
    When I ready with the diagram et will be release here.
    Ditail at 4u2n.dk
    Here
  1. XP System Builder
    By SFiorito in forum WinNT Based
    Last Post: 03-19-2007, 06:13 AM
  2. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-17-2004, 12:38 AM
  3. Mini-box based system?
    By Shaky_Jake in forum General Hardware Discussion
    Last Post: 08-26-2004, 11:11 PM
  4. Replies: 9
    Last Post: 02-28-2004, 10:51 AM
  5. New Headunit with AUX-imputs...My newest addition!
    By outragis in forum General Hardware Discussion
    Last Post: 08-24-2002, 06:25 PM
