Page 16 of 128 FirstFirst ... 6789101112131415161718192021222324252666116 ... LastLast
Results 151 to 160 of 1272
Thread: HQCT Module (new thread following HU RDS/RDBS)
  1. #151
    May 2004
    Actually, designing software should be pretty easy. You need to tell the USB micro to do whatever on the i2c bus. I'm not sure what the code on the USB micro does, but it should simply parse data and commands to and from the i2c bus. It should read the bus for RDS data, fieldstrength level USN, WAM, IF readout, and send commands to the i2c bus like configuration, frequency change, band change, audio setting change, etc.
    It's easier because the i2c overhead is taken care of with the USB micro. So, communication with a HID device is all that is needed. I'm not a programmer by any means, but I think it should be as tough as it seems.
    Jonathan
  2. #152
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Developping a framework is always more work than just developping natively.
    Only if you wanted to support a lot of different hardware, it would make sense. Since there are not many radios out there, I think it complicates stuff a lot, without adding much value.
    If the "market" were bigger, it would certainly be the way to go!
  3. #153
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by racemier
    Quote Originally Posted by TheLlama
    Do you guys know a HID library that works in C or C++? I found a few, but I figured someone here must have some insight.
    we will take a look.
    regards,
    Have you guys found anything? I looked at http://www.frogmouth.net/hid-doco/linux-hid.html It is a HID device. So, it is up to the userspace program to implement the actual protocol. I'm still thinking it would be better having the whole driver as a single device.
    I'm not even that familiar with what HID is. I know it stands for Human Interface Device. But is it a communications standard or just a classification of device? I mean, the radio really isn't a human interface.
    I've looked at the specification for controlling the HQCT and I'm familiar with the parts that are documented. Looks like Hiddev might be a great way to go, but I really need to experiment with the actual device (hint hint).
    Edit: I found an ebook on programming USB device drivers in Linux using Linux's USB-core. It looks like the USB system is fairly simple as far as hardware APIs go.
    Regards
  4. #154
    Jan 2006
    New York
    so any updates on when the tuner will be shipped? - planning on building my system over the next two weeks so i'm planning on integrating one of these tuners. oh has the price been finalized yet? looks pretty awesome jsut can't wait to get one
  5. #155
    Mar 2005
    Wiesbaden/Germany
    Post
    Quote Originally Posted by antimatter
    I dont give a crap how it works or how the front end developers choose to integrate it... as long as they do. And for them to do that it is pretty typical to have a test unit hence my original statement.
    ultimately it is up to raciemer and co
    You will not get rid of a "driver" - if it is extern or internal in the frontend integrated - the internal driver could be buggy - *you* can't replace it with a new version and if the author of your favorite (free) frontend has no intention to continue development - then your opinion may change...
    Quote Originally Posted by JC-S60
    In case your program looks like:
    Code:
    Function Something()
    Redraw Buttons
    DoingStuff
    If Button="Tune up" then
    Serial.Send "HQCT_Tune_up_blahblah...", COM1, 57600
    Serial.Wait "HQCT_Tune_up_Ack"
    End if
    If Button="Tune down" then
    Serial.Send "HQCT_Tune_down_blahblah...", COM1, 57600
    Serial.Wait "HQCT_Tune_down_Ack"
    End if
    End Function
    (you have mixed up internal programm logic with radio-control logic)
    in this case you are right - but this is bad code as it violates the modularisation-rules and you have to be kicked in your butt that it hurts
    Code:
    Module Blah()
    Redraw Buttons
    DoingStuff
     Call Radio_TuneUp
    End if
    End Function
    Function Radio_TuneUp()
    End Function
    End Module
    In this case it means to create a "ClassLibrary-Project", to cut and paste Function "Radio_TuneUp" into the Class Libary and to reference the ClassLibary from the Frontend - one hour work ?
    If you think it is complicated than just have a look at my proposal: shows how stuff works for COM (VB6) and .NET (VB.NET) with a minimal-frontend
    (and believe my that was not complicated ).
    i have also screenshots on my site from the "frontend-programmers-view"
    http://netsh88.hades.net-build.de/fm...diohal/vb6.jpg
    If I get some reactions like "tried your Radiator driver and works" then I will put up a HQCT driver...
  6. #156
    Banned
    Mar 2006
    xtronic.be says end of march, the end of march has come and gone...
  7. #157
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I haven't been on the boards for like a week or two and there still hasn't been any development.
  8. #158
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by bugmenot13
    Sorry, that was what I was expecting... updated the site, hoping this time we'll get it right!
  9. #159
    Jul 2004
    All over the world
    Quote Originally Posted by FMode
    Code:
    Redraw Buttons
    DoingStuff
    End if
    End if
    End Function
    Code:
    Module Blah()
    Redraw Buttons
    DoingStuff
     Call Radio_TuneUp
    End if
    End Function
    End Function
    End Module
    You are completely right about separating everything into layers and that is what we plan to do. However, a COM object is not enough because not everyone will be using Windows. Therefore we have the .DLL that can be used by Windows applications and a kernel module for Linux. However, these interfaces haven hardened yet considering none of the developers have received parts yet.
  10. #160
    Feb 2006
    Quick status update, its over midnight and i want to go to bed!
    As posted previously we got the first batch of 100 modules in and fitted with SMD components, i rigged up a test stand so i could do a preliminary functional test on them. Tested the first one, it passed, mounted the rest of the components and switched it on: it worked. So fase 1 is OK, i then devoted my time to finishing the firmware, got it right, and just finished preliminary testing on another 23 modules, 20 OK, 3 failed (partially). We'll be assembling those and the remainder (that pas the prelim. test) these coming days.
    Quick reminder on features:
    - all settings have to be done via USB
    - the module is a USB HID device, VID is $04D8, PID is $000A
    - the module sends and receives 32 byte reports
    - unit 'remembers' last settings when switched off
    - require both 5 and 12 V DC, connector is disk drive type
    - output is via SIL header, same as sound header of cd player
    - additional 12 pole SIL header to connect Aux, Phone and Nav sound input
    - on same header a digital signal to switch to phone or nav system is provided, this signal is forwarded to the PC via the USB channel
    - the module sends a report periodicaly, this carries the reception level signal, stereo indicator, sync indicator (for RDS), overflow (RDS) IF count (indication of reception quality), WAM and USN figures and RDS data if any.
    - at switch on and on demand, the module send the tuner module alignment data that has to be used to calculate the tuner settings.
    - The HQCT software (that you get with the unit, runs under windows) takes care of these signals and puts them on a display, has input boxes to select frequencies, FM or AM, inc and dec freq., switch to aux, phone or navigation, station identity and decodes RDS data (some of it), since it comes with source code you can adapt it to your likes (some people posting here think it is easy... so have a go at it... )
    Diogenes
  1. [RELEASE - Public]GPSSecure - GPS Tracking
    By xBrady in forum GPSSecure
    Last Post: 03-05-2006, 09:33 PM
  2. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
