Page 45 of 128 FirstFirst ... 35363738394041424344454647484950515253545595 ... LastLast
Results 441 to 450 of 1272
Thread: HQCT Module (new thread following HU RDS/RDBS)
  1. #441
    May 2005
    Germany
    Hi,
    thanks a lot. I think interference and signal quality is my problem, but I didn´t know what to do, because I tested everything.
    1. Antennacable = original BMW fakra to the modul
    2. Modul in a metalbox
    3. Modul away from the pc
    Maybe, someone could help me with an idea for a good signal.
    Ti-ejtsch
  2. #442
    The land of polar bears and nekkid blonds
    Am I the only one to think there's waaaaaay to much bass !?
    Even though Treble is up on max, bass and loudness on min, it's about 2-3 times as much as I have when playing mp3's or cd's.
    /M
  3. #443
    Low Bitrate Stonewall78's Avatar
    Dec 2003
    Calgary, AB
    Quote Originally Posted by Maximus
    /M
    That is more then likely due to the radio broadcast, they like to pump up the low end.
  4. #444
    Feb 2005
    Quote Originally Posted by Ti-ejtsch
    thanks a lot. I think interference and signal quality is my problem, but I didnīt know what to do, because I tested everything.
    Try using a different antenna. The BMW antenna is the shark fin on the roof, isn't it? From my experience, I got a 15% - 30% improvement on signal when using my UHF CB antenna (whilst just holding an unsoldered wire end) compared to using the factory antenna (properly soldered connectors)
  5. #445
    May 2005
    Germany
    Hi,
    no it isn´t a shark fin in the roof. The antenna is in the window.
    Ti-ejtsch
  6. #446
    Low Bitrate lchatela's Avatar
    Aug 2005
    France Annecy
    Yes the antenna is supposed to be good on BMW.So did you try with long cables and with the module in front of the car?
  7. #447
    Feb 2005
    My Jeep antenna is also in the window, and its pickup was impeccible with the factory head unit and the Pioneer that I put in before switching to a carpc. Maybe the HQCT is still not as good as a HU, or maybe it just doesn't work well with window mount aerials.
  8. #448
    Aug 2005
    France Annecy
    I had the same thing before. then I used the same cable as the HU, and the same location for the module (The module itself may receive directly signal from the base antenna connector). If you try that, you will be able to test reception in the same conditions.
    Putting the module in the trunk or in front of the car changed my reception like night and day.
    Now it is close to reception of my HU. To be honest, it is not as good as it was but it is now in the same league.
  9. #449
    May 2005
    Germany
    Hello,
    I have a look at it. The most problem will be the cable for the sound and antenna. I need a cable from BMW (i think ISO) to fakra (module). Is this correct? Can you give me a link for an adapter?
  10. #450
    Quote Originally Posted by Stonewall78
    By a bit, yes, but not this much.
    I'm having similar issues as cdrskull:
    http://www.mp3car.com/vbulletin/show...***#post810489
    But if I lower the volume to "1F" i'm free of distortion, but bass level is very high even though I try to lower everything.
    I'll see if it makes any differance using line_in instead of mic, but it shouldn't.
    Bass levels are not this high using the stock radio in the car.
    /M
  1. [RELEASE - Public]GPSSecure - GPS Tracking
    By xBrady in forum GPSSecure
    Last Post: 03-05-2006, 09:33 PM
  2. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
