Page 46 of 128 FirstFirst ... 36373839404142434445464748495051525354555696 ... LastLast
Results 451 to 460 of 1272
Thread: HQCT Module (new thread following HU RDS/RDBS)
  1. #451
    The land of polar bears and nekkid blonds
    Using the default values from the PDF-file that Diogenes posted sorted the bass problems.
    Strange though that the ones in the sample program wasn't the same.
    http://www.mp3car.com/vbulletin/show...808#post810808
    Code:
    30 40 0F 9F 01 00 30 50 50 74 6F 6A 00 03 00 20 0A 0C 01 01 00 A0
    /M
  2. #452
    Low Bitrate lchatela's Avatar
    Aug 2005
    France Annecy
    There is definitively a problem of initialisation of the device.
    Sometimes it is not recognised after hibernation of after a reboot. It is not related to a bad cable, now I have a good one (soldered everywhere).
    You have then an unknow peripherical and you can't do anything with it anymore (except cutting power of the module or restart several times).
    We need to find a workaround for that, it is not OK like that. I don't know if a software solution can be found because it is more system related.
  3. #453
    Feb 2005
    I haven't had any problems at all with resuming after hibernate. Also if I unplug the USB whilst the radio (and program) are running, then plug it in again, it all works a treat.
    It does seem quite bassy, but not too much. One thing I have noticed though is sometimes I only get output from one speaker. If I adjust the HQCT volume up or down one or two notches, it crackles and pops and then outputs to both speakers again.
    As far as reception, I am using the same factory cable that used to plug directly into the HU, HQCT is about 30cm away from where the HU used to be. Without moving the HQCT, I can improve reception 50% by using a whip antenna.
    Still not sure what relationship the "level" number has with signal. Some stations sound fine with a level of 90-100, and some are unlisteneable when the level shows 110-120.
  4. #454
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by froop
    The signal is not always related to the soundquality. What is important is the Signal / Noise ratio. If the station is at 90 and the noise at 70, you'll get 160 but very bad sound. Don't know if the s/n ratio can be measured though...
  5. #455
    Oct 2005
    Signal strength issues: Anyone try an amplifier yet?
    I have yet to try out my receiver, but after reading several posts, I am fully expecting to have signal quality (low strength) issues.
    - Has anyone tried placing a signal amplifier between the antenna and this unit?
    I know that some poorly designed amplifiers can cause more problems than they solve, but I will certainly consider using one if I find the reception unacceptable.
  6. #456
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    On some systems, some USB devices have significant issues after hibernation and/or standby. There are some work arounds. If you can searxh the forum for USB and hibernate, I bet you will find a solution. This is NOT necessarily a problem with the HQ, but an issue with your system and with Windows.
    Michael
    Quote Originally Posted by lchatela
  7. #457
    Aug 2005
    France Annecy
    Quote Originally Posted by Wiredwrx
    Michael
    It is not only a problem of hibernation that you may solve using devcon.
    It occurs when starting the pc and can't be resolved by repluging the device (so devcon won't help). The only solution it to restart the device. It's seems to be an initialisation problem.
    As you may read in previous posts, it is not only related to Windows. So there is only 1 workaround today: - put a switch on the module to restart it.
    This is a real issue and the sellers should try to find a solution before producing the next batch...
  8. #458
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Angry
    Bad news everyone!
    Today I magically corrupted the filesystem on my car-puter. The source code for the kernel module and C api have been lost. Fortunately they are still in my head and should only take a few hours to re-write.
    The biggest issue is the time needed to deploy a new gentoo system. So, things may be released a few days later then I expected.
    EDIT: I wired the radio up to my real computer while I recompile Linux onto my car-puter. It's been several hours (and several beers) later, but I have the kernel driver to the point it was earlier. In fact, I spotted a few problems and it is even better. I'd say a test version will be available on Saturday.
    Do I have anyone willing to test it out?
  9. #459
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Well this radio sounds good but every time I reboot, hibernate or shutdown it comes up with unknown device in the hardware manager and the only way I have found to get it going again is to unplug the power from the board and repower up.
    The only thing I can think that would cause this on my pc is the power is getting to the board from the power supply before the usb port.
    So could I take the 5v power from the usp and switch it with 5v from the power supply?
    The only other solution I can think of is a time delay relay on the power supply cable
    Or a 5v relay controlled from the usb port to turn on the power from the power supply
    Edit
    Well the 5 volt relay fixed mine 100%
    So my theory about the power from the power supply getting to the board before the usb power must be right
    2001 S10 ZR2
    Chucks Skin - to old
  10. #460
    Aug 2005
    France Annecy
    That's a very good information!
    I will try that!
  1. [RELEASE - Public]GPSSecure - GPS Tracking
    By xBrady in forum GPSSecure
    Last Post: 03-05-2006, 09:33 PM
  2. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
