The module works for me like a charm. It is 100% working without any flaws now. Here is what I did....
- I removed the 5 pin SMB antenna connector from the pcb (took some effort because I had a simple solder gun and not that powerful)
- I bought a GOLD plated SMA female connector (5 pin right angle PCB mount style) and soldered it on the pcb. (part # ARFX1232-ND from
www.digikey.com). The reason for replacing SMB with SMA is because the SMB jack is a clip on type and has a lock mechanism which makes it very hard to remove the cable once put on. I broke my cable while removing it from the module. But the SMA connector is a screw on type so you can connect it and disconnect it effortlessly.
- Since my car (G35) has a built-in antenna in the rear windshield and it was not giving good reception with this module, I decided to buy a new roof-mount antenna (i used the one that comes on Infiniti FX-35.... i think it looks cool). I had to drill a hole on my G35 roof and install the new antenna. BTW this antenna has a built-in signal
amplifier, so I had to
power it from car's 12V.
- I had bad experience with the SMB to motorolla type adapter, so this time I decided to eliminate using any type of adapters. I bought RG316 Cable with SMA Male (gold)
connectors on both end, 10.0 ft (part# CCSHR316-10 from
www.L-com.com).
- I cut off the SMA connector from one end of the cable and I also cut off the connector from the roof-mount antenna cable. I then very carefully crimped those two cables together (eleminating the need of any cheap quality adapters).
- I connected the cable to the new SMA connector on the
radio module.
- Before doing this modification I was receiving only 2 radio stations and those with very very bad reception as well. I crossed my fingures and turned on the car. I was only expecting to see some better reception and may be few more radio stations. Guess what? I was blown away by the result. I was getting like 25 stations out of which 22 had 100% streo quality reception. No breaking up either. I went to work and back home (about 120 miles) and through out the entire ride not even once I lost any reception. Throught the ride I just kept on saying HOLLY ****... HOLLY F****** ****!
I now have way better reception and many more stations than what the original car radio got.
Sorry guys for the long post, but I am very exicited and had to share it with all of you. May be you guys can try making your own cables and solder SMA GOLD connectors on your radio pcb!
