Page 56 of 128 FirstFirst ... 6464748495051525354555657585960616263646566106 ... LastLast
Results 551 to 560 of 1272
Thread: HQCT Module (new thread following HU RDS/RDBS)
  1. #551
    Constant Bitrate lifeboat's Avatar
    Nov 2001
    Oregon Coast
    Quote Originally Posted by TheLlama
    Odd, my unit keeps the same volume after recycling power. In fact, it keeps all of the settings. Do you have the HQCT running through the soundcard? My guess is that the soundcard's hardware volume is too high.
    My HQCT does keep all its settings, what I mean is that I can't mute it or adjust the volume until Windows is loaded which takes about 30 seconds or more. It's not like a headunit where you have immediate control of volume at power on, so if you want quiet when you start the car in the morning you're out of luck. My soundcard has output the second it recieves power so the radio plays while the machine is still booting. So I need a way to either control volume on the HQCT without windows, or make it be quiet until windows is loaded.
    One nice feature I had with my Blaupunkt HU was you could set the start-up volume seperately.
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
  2. #552
    Low Bitrate Enak's Avatar
    May 2004
    Hertfordshire, UK
    The unit keeps it's last settings...
    What you need is some software to set the shutdown volume when you shutdown your pc.
  3. #553
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    yea right
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  4. #554
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by lifeboat
    OK, so mute the radio before shutting down. I don't see how you expect to control a usb-controlled device before a usb host is connected to it. I'm not familiar with Windows, but I know you can easily run programs automagically on shutdown in Linux.
  5. #555
    Nov 2001
    Oregon Coast
    I don't expect to have direct control of it without USB, but that's exactly the problem. I also don't want to have to manually lower the volume every time before I turn the car off, the whole idea of an integrated system is automation, everything should start up and shutdown gracefully without user intervention.
    The best thing I think would be an option in the HQCT software that programs the HQCT to power on at a reduced volume, independent of the primary volume setting. The idea being that the HQCT would power up at the reduced level, but as soon as windows loads and the HQCT software is loaded it would return to whatever was set in the software. I don't know if the hardware even allows such a setting though.
    The only other thing I can think of is maybe an AutoIT script or something to send a command to the software at shutdown. Over my head at the moment, I may mess with it when I have more time.
  6. #556
    Jul 2004
    All over the world
    Unfortunately, that functionality would have to be implemented in the HQCT firmware. I'm surprised Windows will not let you execute a binary upon shutdown. It sounds like it should be a straight-forward procedure. Anything in msconfig ?
  7. #557
    Feb 2005
    I don't listen to radio directly through the line-in line. Because I use SPDIF out, I have to use winamp with its linein plugin to redirect the radio back through the wave line. That means that I don't hear radio until winamp starts. It also has the side-effect of including a delay or 2 or 3 seconds for the digital encoding of the audio, which isn't too much of concern after you get used to waiting a couple of seconds after selecting a new station.
  8. #558
    Jul 2004
    All over the world
    Quote Originally Posted by froop
    Have you checked if you can adjust the buffer size your sound card uses while encoding?
  9. #559
    Newbie Blondie's Avatar
    May 2006
    Takoma Park, MD
    Can any one recomend where to get an SMB cable for the HQCT stateside?
    You see, in this world they’re two kinds of people, my friend: Those with loaded guns and those who dig. You dig
  10. #560
    Feb 2006
    Castle Rock, CO
    I got my SMB connector from Fry's electronics in california. It was actualy an XM antenna. I don't have the model number on me. I get Ok resception, It gets fussy hear and there. It's lot better then my Dlink fm radio.
  1. [RELEASE - Public]GPSSecure - GPS Tracking
    By xBrady in forum GPSSecure
    Last Post: 03-05-2006, 09:33 PM
  2. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
