Page 7 of 128 FirstFirst 123456789101112131415161757107 ... LastLast
Results 61 to 70 of 1272
Thread: HQCT Module (new thread following HU RDS/RDBS)
  1. #61
    May 2004
    Well, it's intented as another software option for these units racemier is building. I think there is an i2c port on them that can be connected to a pc via parallel port. If you want to host it, you're welcome to download it and host it. Philips sent it to me. It's really sweet software because it does RDS/RBDS decoding and controls and aligns the TEF audioproccessor and tuner used in racemeir's design. It aligns the tuner really well and makes it sound really good.
    I've used the old microtune software and it doesn't align the tuner that well. It's buggy and doesn't work the best with i2c. It doesn't utilize the performance of this tuner fully, the philips software does. It's quite amazing the difference. One critical step in getting the most out of this tuner is aligning it properly. I'd personally use the philips software, but anyone is welcome to use any software they like.
    Jonathan
  2. #62
    Aug 2004
    Update
    Hello,
    Small update:
    PCB panels arrived, next week they go to the assembly company.
    Afterwards programming and ready.
    Professionals built the Titanic, an amateur built the Ark.
  3. #63
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Thumbs up
    Sound exiting, can't wait for it. Sometimes I like to listen to the darn radio.
    Good Job guy's
  4. #64
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    can't wait
    I want to pre order it
    NOW
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  5. #65
    May 2004
    racemeir,
    Have you tried that software I posted? How well does it work with your design?
    Jonathan
  6. #66
    Aug 2004
    Hey Jonathan,
    I'm not able to download the sw from the link, it gives page not available.
    Most probably because you only host a files which is not allowed I saw in the regulations of Yahoo.
    Could you mail to file to hqct@datalex.be?
    Or you need to make 1 web page on that site.
    Regards,
    Rogier
  7. #67
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Straight to the top we go.
    We are, will have and forever will be...
    But not tommorrow!
  8. #68
    Aug 2004
    Hi,
    If everything continues going according plan we will get back the PCB's from the assembly company this week. This means that we have to program them and test them and send them out.
    Regards,
    R
  9. #69
    Nov 2004
    Italy
    \o/
    good news
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  10. #70
    Feb 2006
    Hi everyone,
    time for some update:
    i tried the Philips software we got trough 'emumanXM', had to fiddle the interface and our prototype but got it working, it is great softwre indeed, however you need 20 pairs of eyes to see everything that happens, anyway, the conclusion is that our project performs very well, our sample software has the very same capabilities as the Philips soft, logically since we use the same control strings, interesting however is that for certain settings different approaches are possible (i used 100 kHz ref so far, 10 kHz gives finer tuning possibilities...) but the tool is there, just expand on the sample soft.
    The tuner firmware sends a report (32 bytes) at regular intervals if no RDS data is received, in case of RDS the firmware sends the report as soon as new data is received, this way there is no data overflow in the receiver.
    To control the module the PC software sends reports (32 bytes) where the first byte is the data bytes count, the second byte can be the I2C adress of either tuner chip or multimedia control chip, the following bytes all have particular meaning and do control the various settings of the tuner module.
    I' ll dedicate a separate post to cover all details.
    The report from the tuner module contains reception level, stereo indicator, RDS data and reporting, this is info that the TEF generates, the IF count and status of 3 8-bit ports of the controller are added as wel, again, next post with more details.
    We are now setting up a testing rig for the first production batch due this week!
    diogenes
  1. [RELEASE - Public]GPSSecure - GPS Tracking
    By xBrady in forum GPSSecure
    Last Post: 03-05-2006, 09:33 PM
  2. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
