Page 75 of 128 FirstFirst ... 25656667686970717273747576777879808182838485125 ... LastLast
Results 741 to 750 of 1272
Thread: HQCT Module (new thread following HU RDS/RDBS)
  1. #741
    Sep 2005
    Sweden (South)
    which software are you using?.. could be an alignment issue.. The free sample software should work, my HQCTS as well.
  2. #742
    Constant Bitrate Paul C's Avatar
    May 2004
    West Sussex
    is it possible to still pre-order these units?
  3. #743
    Constant Bitrate ankur's Avatar
    Aug 2006
    New Delhi
    I think you can still order at http://direct.xtronic.be/shop , although i think there is a long backorder list. I am on it.
    cheers.
  4. #744
    May 2004
    West Sussex
    Quote Originally Posted by ankur View Post
    cheers.
    well that was my first port of call as thats the web site where you buy them from but when you add it to the cart all I get is "This item is only available for people who pre-ordered" so hence why I ask if you can still pre-order
  5. #745
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    Quote Originally Posted by DeLorean Dave View Post
    OK so I put in a new antenna into the DeLorean and I still seem to get poor reception. Signal strength readings of between 25 and 45, fluctuating a lot. Fuzzy, out of tune like sound. Any suggestions? (Note HQCT in upper right side of lower photo.)
    well, try to wire it directly to the flux capacitor and see if it boosts your signal
    ok ok, too easy I know
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  6. #746
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by Paul C View Post
    Pre-ordering is suspended for a while, to get the list to shrink.
    Another 65 people are able to order now, so soon we'll have normal orders available!
    Joachim
  7. #747
    Mar 2004
    Ghent - Belgium
    Hmmm, I'm running out of ideas personally... Have you tried using it further away from the mainboard. Maybe some interference from the non-isolated mainboard causes issues...?
    The module should be doing much better!
  8. #748
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by Frankino View Post
    Maybe you'll receive baseball game results from the future then!
    Imagine the possibilities!
  9. #749
    Feb 2006
    i would look in two directions,
    one: use the latest PC software, the early versions did not read out the alignment values from the tuning modules, this results in 'fuzzy' receptions in some cases (the default values are close but not 100% correct) software is available for download on www.datalex.be, on www.xtronic.be from aeroanders, from the Llama (Linux), and i think RoadRunner does it as well (i did not get confirmation from Guino, so i am not sure)
    two: there could be a 'mechanical' problem : The connector on the module (male SMB) has a pin inside. It could be this pin is bent or broken off, in that case you would not get a correct antenna connection, hence poor reception. How to test? Visualy, i use a magnifying glass to check the presence of the pin;
    Trial: take about 1.5 meter (6 ft) of stranded wire, leave as much as possible out of the car and stick one end IN the connector on the module, or, if you can, solder it to the center pin (of the connector) on the bottom side. If you have one around you could do the same with a whip antenna (forgetting the ground connection for this test). If this gives a better result you must check the antenna connection again.
    Diogenes.
  10. #750
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    So is this a FM solution?
    What's up with this?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  1. [RELEASE - Public]GPSSecure - GPS Tracking
    By xBrady in forum GPSSecure
    Last Post: 03-05-2006, 09:33 PM
  2. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
