Hi,
thanks!
The antenna is connected to power!
Ti-
Is the antenna an active antenna, that needs power in order to operate. Have you tried going to a car parts store, and getting an antenna, and connecting it and seing if the reception improves? If not, then you can return the antenna, no harm no foul, except for some time.
Michael
Hi,
thanks!
Ti-
Try a different antenna. There are several reasons. First, the active antenna may not play well with the HQCT. Also, there may be "ground loop" issues, since the HQCT is powered form a different source then the Antenna, which might introduce significant noise and interference.
Michael
time circuitery gets activated at 88mph according to Doc Brown calculations, it's imperative to reach that speed![]()
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Just a thought I have... Would it be possible to "switch" the HCQT-module to listen/decode TMC-data whenever you dont listen to any radiostation, since the GPS-devices with TMC functionality are quite expensive, and it seems a little bit unnecessary to have to RDS-modules.
might be a stupid question but what is TMC, and why would you want it
I've noticed that there are still people owning a HQCT tuner and using the demo application from Datalex, am I right? I recently wrote my own app to control HQCT that stores its settings when closed and with a bit more features then the Datalex demo. Its written in Delphi for a screen resolution of 800x480. If your interested, PM me and I'll send it to you by email. (The zip file is 1,2MB in size) Or if there's somebody out here who can host it somewhere is also ok for me. The interface is straight forward so ne helpfile is needed (I think) I'm not a graphics designer (more a ski-fanatic
) so dont start asking for other backgrounds or different colors for the buttons etc I wrote it for personal use and I just want to help people who are still using the Datalex app.
Still I'm open for suggestions/criticism![]()
Note: It doesn't require/integrate with any existing frontend, its a standalone program that only requires the mcHID.DLL from Datalex.
Screenshot:
