+ Reply to Thread
Page 80 of 128 FirstFirst ... 30707172737475767778798081828384858687888990 ... LastLast
Results 791 to 800 of 1272
Thread: HQCT Module (new thread following HU RDS/RDBS)
  1. #791
    Variable Bitrate seninha's Avatar
    Dec 2005
    Holland
    Quote Originally Posted by Diogenes View Post
    Hi;
    you are not doing anything wrong, the HQCT software always defaults to the same values at start-up, i will add a ini file with the next release, i do have to add some controls for the HQCT-eA, this one is on test now and will be available shortly.
    BTW, the HQCT module does save its last settings.
    In case you missed, Putput has a version out with ini file, there were some bugs to be fixed so watch out for the final version.
    Also Fmode is working (hard) on producing a version of a more universal control.
    Okay, lets see if I understand this:
    So I open HQCT.exe (in my case RRHQCT.exe), change what I want. Close HQCT . Then open RoadRunner , start the radio and listen the way I want.
    or is this the way to do:
    open RRHQCT.exe,change the settings, leave HQCT.exe open . Start Roadrunner and listen to the radio.
    Now , is solution 1 or just 2 the way to do it.
    Gods right foot!!
    Renault Grand Espace 3.5 V6
  2. #792
    Mar 2004
    Stockholm, Sweden
    Quote Originally Posted by seninha View Post
    Option 1 is the way you should do it.
  3. #793
    Mar 2005
    Wiesbaden/Germany
    Screenshots (showing the (RDS)features offered to Frontends) will be published soon...
  4. #794
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by FMode View Post
    Great, is the new RDS code going to be open sourced so I can use it to help with the Linux version? I should be able to get around to it in December after I graduate, take the GRE, and get Grad school apps in.
  5. #795
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Smile
    Quote Originally Posted by Wiredwrx View Post
    You're joking, right?
    READ THE THREAD, OR AT LEAST THE FIRST POST.
    Don't be lazy.
    Michael
    It's just that I've tried so many FM things with no success.
    I don't wanna drop another $150 and be disapointed again.
    So I guess I'll pick one of these up and see if this will add FM in my car since I haven't had FM in it since 2003. Just been playing MP3's.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  6. #796
    Mar 2005
    Wiesbaden/Germany
    Quote Originally Posted by TheLlama View Post
    Yes I will publish the source... and i think its only needed if someone wants to port to other platforms than windows (and to look if he/she wants to write a driver for another radio)....
    as the driver and the RDS interpreter is in .NET may be you can exchange mchid.dll to http://www.sharpdevelop.com/OpenSour...b/default.aspx and you are ready for Linux/Mono !
    (I hope Mono develops quickly - .NET RULEZ sooo much)
  7. #797
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    weeks...
    Do you have a rough price estimate at this stage?
    We are, will have and forever will be...
    But not tommorrow!
  8. #798
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
  9. #799
    Dec 2005
    Tampa, FL
    HQCT -- Help
    Last night I received my HQCT.
    I connected all the wires to my CarPC, USB header, power, sound out and antenna. I downloaded the latest app from your site. I started the PC and upon startup I heard static. I ran the program and it shows that it is connected via the USB. I have tried changing the channel, switching to AM and just about every other button on the app but I keep getting the same station (with horrible reception).
    Please help,
    What can I do to troubleshoot this issue?
    Hardware: VIA-SP13000, M2-ATX, Voom case, HQCT, Linksys WiFi, Bluetooth, 512MB, 80GB, Dynamix 706.
    Software: XP Pro (stripped), Drivers only, Road Runner, CentriFuse, EzSync
    99% done... [never completely finished... a continuing hobby]
  10. #800
    Feb 2006
    Quote Originally Posted by tonysch View Post
    HQCT -- Help
    Please help,
    Hi,
    sad indeed.
    few things to check : disconnect the USB from the module, then cycle the power (power off and then back on, if you can only the module), wait a while then plug in the USB, after that run the program (HQCT or the latest RRHQT), observe the screen, wait till all is stable except the level readout, then type in the frquency of a known (strong) station, hit the 'FM' button, and then 'FreQuency FM'. Observe carefully what happens on the screen.
    Do check you get signal from your antenna, if it is a type with amplifier make this amp gets power. Take a piece of stranded wire (speakercable), leave some of it outside the window and (gently, so you dont break off the pin in the antenna socket!) push the wire into the antenna socket.
    Question: do you get any reaction when changing the volume?
    Diogenes.
+ Reply to Thread
  1. [RELEASE - Public]GPSSecure - GPS Tracking
    By xBrady in forum GPSSecure
    Last Post: 03-05-2006, 09:33 PM
  2. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
