Results 1 to 5 of 5
Thread: Voltmeter
    Low Bitrate girbot's Avatar
    Feb 2006
    Houston, TX
    Voltmeter
    I was looking at power supply options and a though came to me, get a voltmeter to see if you system is pulling to much power. I don't know if any one else has though of this (I bet some one has). I found this one for cheap:
    http://www.cardomain.com/item/ATM2356
    Wireing is NOT included, so what would I need to wire this thing up?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    the back most likely has to posts with nuts on them. You will need 2 ring terminals (round wire ends with a hole in them), and a length of wire. Crimp terminals to wire and connect to a ground and a V+ source.
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    There's the Schumacher BT-25 digital gauge. More accurate, but you won't see the needle dip when the bass hits like an analog gauge. It's made for surface mounting, but you could mount it behind some tinted plastic.
    Here in Canada they're $20 at Canadian Tire.
    http://www.jegs.com/webapp/wcs/store...0787&langId=-1
    Or search Ebay using digital panel voltmeter; there's some blue LED meters there for about $20.
    Any auto parts store will have some analog voltmeters, or go to an auto parts swap meet and you'll find some cheap used ones. You could get an ammeter gauge too to monitor current into the power supply or inverter.
    Feb 2006
    Houston, TX
    sweet find, thanx. I fill pick one of these up instead, thankfully I havent ordered the other yet. Your comment on how the analog on would move when the bass hit, are they that sensitive?
    You know you're an engineer if you have no life & can prove it mathematically.
    Newbie fission7x's Avatar
    Dec 2005
    SE-USA
    Anyone know of a way to get the computer to read the car's voltage and display it on screen?
  1. Looking For USB Voltmeter or simliar device
    By mukow in forum General Hardware Discussion
    Last Post: 09-17-2009, 12:49 PM
  2. Replies: 22
    Last Post: 03-04-2006, 09:35 PM
  3. Audigy 2 NX power hookup
    By agent4877 in forum General Hardware Discussion
    Last Post: 12-16-2005, 03:52 PM
  4. digital voltmeter = interference??
    By owibitmytongue in forum General Hardware Discussion
    Last Post: 09-01-2004, 08:26 PM
  5. looking for a small voltmeter
    By aoLhaTer in forum LCD/Display
    Last Post: 08-19-2004, 02:50 AM
