Results 1 to 10 of 20
Thread: Boost Gauge
    Dec 2004
    Boost Gauge
    I wanted to either find for purchase, or design and build, a boost gauge for my car, so rather than having a gauge sit somewhere on the dash, I could have the readout on my screen.
    I know Phidgets has a PSIG meter which you can use with an API setup. Does anyone else know of other solutions or somewhere to purchase something pre-made?
    I just need 0-20psi.
    Tainted Love Cris's Avatar
    Romania
    Why not use OBDII?
    Mar 2004
    Vancouver, BC, Canada
    You can't get boost pressure through ODBII. You would need a proprietary protocol that is car specific to be able to read boost.
    Low Bitrate Daley's Avatar
    Oct 2005
    H-Town
    I think I'd personally go with the Phidgits option. You'd need to build yourself a front-end for it, but at least you wouldn't have to worry about drivers and all that.
    BTW, what kinda car? Being a gear-head, I'm just curious.
    To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
    If it's not fun, you're not doing it right!
    Dec 2004
    2005 GTO CGM-M6
    Can't use OBDII for the reason he said above, plus, the car doesn't come stock with any boost devices
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you could use a regular boost gauge and have a shaft encoder on it to the PC. Or look for a pressure transducer. quite easy really but the former is easier to calibrate in a way.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Scouse Monkey
    the gauge wouldnt be able to turn a shaft encoder
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Low Bitrate Stonewall78's Avatar
    Dec 2003
    Calgary, AB
    Take this article from Audi world and work from there http://www.audiworld.com/tech/elec94.shtml
    Also boost data via OBDII is going to be way to slow to be useful.
    Mar 2004
    Bristol
    Quote Originally Posted by scott_fx
    yes it would. i bet you.
    optical ones have no drag.
    Dec 2004
    Los Angeles Ca
    i didnt even think about an optical encoder. you are correct sir!
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Any Gauge Face Creation Ideas?
    By xhazn in forum Fabrication
    Last Post: 05-18-2005, 08:09 AM
  2. Replies: 22
    Last Post: 03-09-2005, 10:27 AM
  3. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 09:01 AM
  4. WRX owners. Clock or Boost Pod Gauge area. Center channel Speaker.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-02-2004, 04:37 PM
  5. question about relays and high gauge wires
    By Heedunk in forum General MP3Car Discussion
    Last Post: 05-10-2001, 11:13 AM
