Results 1 to 10 of 10
Thread: Determine Transmission Gear
    Oct 2005
    Oshawa
    Does anyone have any ideas on how to determine what gear you are in, mind you this is on an older car, a 94 Dodge Spirit, its a floor shift Automatic, I was thinking of making a ribbon controller and then using the ADC on a PIC to determine what gear I am in, but does anyone have any better ideas?
    Hey Laserlips, your momma was a snowblower!!
    Sep 2005
    with an automatic?
    first: why?
    second: you would have to hack the valve body. I'm very mechanically inclined, and I hesitate to mess with valve bodies, unless I have another car to drive. You probably WON'T get it right the first time when putting it back together.
    Fusion Brain Creator
    Mar 2005
    wrong, wrong, wrong
    REAL simple
    GPS speed / RPM -> program a range
    in other words, if you're doing 70mph and the engine is spinning 2500RPM, you're in 5th gear,
    Oct 2005
    Oshawa
    Maybe I should've worded it differently, I'm going to have a small 4" LCD inbetween the gauges in the dash for Navigation and other Info, and I want to display R, F, N, D, OD and maybe highlight whichever one I am currently in.
    Mar 2005
    what is "F" ?
    do 4x IR emitter/detector pairs, installed below the shift trim, so that the shift handle blocks a E/D pair, resulting in data
    Jan 2006
    what is the setup currently, if there is some sort of lighting for this anyways you could likely just mod it
    98 V6 Camry XLE
    Status-Everything is working again!
    No progress while I am in NYC
    Ze Worklog
    Oct 2005
    Oshawa
    I meant P not F, i have no idea how I made a typo like that, anyways, the IR E/D sounds like a good idea, but I will check to see if there is any lighting like Anshu suggested, first.
    Thanks for the ideas
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i would think you should be able to use a relay pattern and, and a hacked usb device. when voltage is running through the lamp for P R D..... you could use a relay to close the circuit for a button on a HID game controller
    PC Components:
    My work log
    Banned
    Mar 2006
    I want F on my shifter FLY!
    magnetic switches?
    http://dakotadigital.com/index.cfm/p...prod/prd64.htm
    Apr 2006
    Ohio
    If it's an electronic tranny, it's likely just a wire with a variable current or resistance coming off the shifter. This is the case on Fords, though I don't know about Mopars.
    Regardless, it should be easy to tap. Those of you thinking about the valve body, you need to think simpler. Position sensing on the shifter is very simple, and as long as he just wants his carPC to display the selected gear and not real-time tranny info, that's all he needs.
  1. TOP GEAR! YAY! We got it!
    By wizardPC in forum Off Topic
    Last Post: 12-31-2005, 08:58 AM
  2. Replies: 2
    Last Post: 09-07-2005, 12:31 PM
  3. FS Wireless gear & 15ft M/F parallel cables
    By Hamburglar in forum Classified Archive
    Last Post: 02-09-2003, 04:56 PM
  4. How to determine your LCD/Backlight nit value
    By SillyClown in forum LCD/Display
    Last Post: 10-10-2002, 07:24 PM
  5. Game Gear
    By kane2g in forum General Hardware Discussion
    Last Post: 11-29-2000, 03:26 PM
