Page 15 of 70 FirstFirst ... 567891011121314151617181920212223242565 ... LastLast
Results 141 to 150 of 695
Thread: Project NiteVision - NiteMax + HUD + carputer
  1. #141
    Constant Bitrate NiteMax Mark's Avatar
    Feb 2006
    Quote Originally Posted by jammy_basturd
    Ahhhh, so it really would take some work to produce a HUD using one!
    Instead of trying to figure out how to drive the MEMS display, you can start with the NiteMax LCD -- you'll have a fully functional color video display. With a little care, the back-light can carefully removed from the LCD itself. With the back-light removed you'll have the equivalent of a electronically controlled "slide" because you can actually see through it. Build up the optics as if you were building an overhead projector and you'll have a working projection system for cheap.
  2. #142
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I'm with Mark. It's interesting, but I'll bet it would be 100 times harder to figure out how those work without datasheets (nevermind the other stuff to get it working, and it says they might be scratched or broken).
    In other news, found a cheap fresnel 3X magnifier at CVS for $2.
  3. #143
    Newbie TomG's Avatar
    Nov 2005
    well I haven't contributed much to this yet but I've been working silently in the background
    I've got a system set up as follows now:
    one Nitemax body with the image on the screen flipped horizontally.
    one switch on the body to power on and off the CCD(s) so the video out becomes video in.
    two CCDs connected via a selector switch and both mounted externally along with a single set of IR LEDs.
    one of the CCDs is a standard B+W one and will be used for forward facing night vision, the other is a colour one with its image flipped onboard so it appears the correct way round on the screen
    the switch will be replaced with one in the gearbox or at least linked to the one already there so that when reverse is selected, the colour camera is selected and as the image has been flipped twice, the image will appear the correct way round when used as a HUD.
    The video in is connected to a car pc so I can switch over to sat nav display on the HUD, this is switchable to an output and that goes into a capture card which in turn goes to the pc.
    I will hopefully find a way of overlaying the sat nav on to the night vision video feed so I can get night vision and sat nav on the HUD simultaneously, but I'm currently having problems getting the damn capture card to work at all
    One question though, when the PC data is displayed on the 2.5" LCD, it is B+W. I know the screen is fine as it displays colour from the colour CCD as well as from my digital camera as a source and a VCR. Why is it doing this and can it be fixed? I've tried all the range of TV signals (and in turn frequencies) to no avail.
    ta
  4. #144
    Mar 2005
    NY
    I too have been thinking about the simulatneous display, esp after meeting with alti at the NYC meet yesterday afternoon (i feed off smart people, jk jk). Have you tried getting a transperancy program? I've used them with MSN Messenger (msnplus, good stuff!). Basically, you want the iguidance to be the one that is in focus, so it should be on top and mre transperant. Keep it in night mode (black is most transperant). I'll take a screen shot of what i'm saying later on in the day.
    What TV capture card are you using? So it displays data from the color CCD in color from the computer in B&W, but color only from a direct feed?
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  5. #145
    Apr 2005
    Boston, MA
    Ok. Did some playing. I found an even better way to mount the front camera.
    Instead of mounting it to the mirror mount, I added a 2" tab to the top of the camera, sticking out backwards.
    Then I just slid it right under the headliner. Perfect.
    Still some problems to work out. The cameras are just to damn sensitive and it's not compensating enough.
    Couple notes.
    Shot this morning about 6:30am. All vids are Divx encoded. You can normally see some glare from the dash, but even more noticable though the camera.
    You can see in this first vid, how bright the headlights appear, even in daylight.
    Front Cam 1 - 5897 KB
    Front Cam 2 - 6238 KB
    Front Cam 3 - 6953 KB
    A couple minutes after these vids, it got very overcast and oddly enough, it kills the picture. Totally drowns it out. The next vid illustrates this. I'll have to play with some of the pins on the camera and expirement with the gain controls again.
    The first few seconds are of my original (and expensive) SAVV backup cam. You can see how noisy and unbalanced the pic is at night.
    Front Cam 4 - 3994 KB
  6. #146
    FLAC alti's Avatar
    NY
    thanks for the vids, shotgun, they really help.
    The headlights are distrubingly bright, and the proplems with glare on the windshield is apparent. I am starting to think that it might be a good idea to start investigating how to mount the camera on the front of the vehicle.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  7. #147
    FLAC alti's Avatar
    NY
    Quote Originally Posted by TomG
    ta
    awsome, do you have any pics??? I would love to see what it looks like.
    I dont have an answer to your question unfortunatly, I have not not tried to use the nitemax screen to display anything other then the output of the camera.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  8. #148
    Apr 2005
    Boston, MA
    Quote Originally Posted by alti
    To be fair, I don't think with a stock dash you'd have nearly as much problems.
    Mine is quite shiny the way I finished it.
    I've tried two of the Nitemax Ultra CCDs and they are both the same concerning light brightness. I might try a lens with a higher F-stop. Or maybe give a polarizer I shot. I think of something..
  9. #149
    Mar 2005
    NY
    Hehe, just watched htree and was half expecting you to blow that stop sign Have no idea why though. I have to agree with alti. Though in the daylight this is probably more apparent, its too apparent.
    See, i wanted to have it installed at the bottom of my windshield at the corners to try to prevent this. However, you don't get a great view of the road other than the road ahead. And hell i want to see the squirrel just before i run it over (jk jk).
    My car is black, so i can pretty much mount it whereever with less chance of anything being seen, but the two BEST exterior places is in the front lip where people cut out for headlights, but knowing me, its definitely going to get damaged or dislodged, plus i want something a little higher, or in the grill, which i'm not too keen on doing either
    EDIT: (at the pic above) Well that could explain it... Would a polarizer be a good choice for a low light camera though?
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  10. #150
    Apr 2005
    Boston, MA
    Quote Originally Posted by Genesisfactor
    See, i wanted to have it inwtalled at the bottom of my windshield at the corners to try to prevent this. However, you don't get a great view of the road other than the road ahead. And hell i want to see the squirrel just before i run it over (jk jk).
    It also looks faster than it is due to the lens I think. 40mph was about the fastest I was going in any of those.
    Funny though, in 3, that corner, half way around the park, is a really tight turn. Everything in my trunk flew to the other side. In the video, it doesn't look tight at all.
    As far as cutting down the light, I dunno, it's damn sensitive.
    Look at the previous post with the night shot.
    Even the traffic signals which are fairly dim and directional look like novas.
  1. PROJECT: 2004 Xterra Carputer
    By elgenyo in forum Fabrication
    Last Post: 06-01-2007, 04:23 PM
  2. VW Golf mk3 - carputer project
    By Sh0cker in forum Show off your project
    Last Post: 12-09-2005, 10:14 AM
  3. My Carputer Project, need advice
    By natesimpson74 in forum General Hardware Discussion
    Last Post: 09-21-2005, 01:14 AM
  4. My carputer project: Solaslim
    By nthai in forum Show off your project
    Last Post: 10-28-2003, 03:43 PM
  5. New CarPuter Project: Need Input!
    By Tremek in forum General Hardware Discussion
    Last Post: 01-31-2002, 03:07 AM
