Looks a little big for a dash, but nice.Originally Posted by Custommx3
Check this...
http://www.kollsman.com/company/news/pr_11152005.asp
They are comming to my work to display this according to a co worker. I was invited to the demonstration and will try and take pics and post them.
Hes going to call them soon to setup a demo, but there is no deffinative date as of yet.
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
neat looking at this stuff
http://www.el-op.com/default.asp?cat...EB41669D20C%7D
i always thought they had transparent LCD overlays, i didnt realize all huds were projected
PC Components:
My work log
What about something like this?
http://www.apollodisplays.com/ArtistaUSB.php
or this
http://www.brilliancorp.com/PDF/N2E/..._CEK_BR_E2.pdf
nice find! easy to get multple display this way. I wonder how much video a usb bus can handle before it slows down
Current:
[BMW E46 ///M3 Convertible]
Previous:
[BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
Hey mark or shotgun, have either of you figured out how to get S-Vid to work or should i stick to RCA? I'm about to take apart one of the cameras just to see it work
Also, mark, i'm getting inconsistent powerons off the car adapter. What could be causing that? When it works, it works great, when it doesn't it doesn't. The sad thing is that the image it produces is alot cleaer than my eyes can see...and the nitemax has been a very useful Ops tool![]()
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Haven't spent any time on it as of late. Honestly, at that resolution, I don't know if you'd see any big difference from Composite vs VGA.Originally Posted by Genesisfactor
I did order any auto-iris lens to hook up the the Ultra Color CCD. Hopefully that will help with the night shots.
Found some cheap TV projection lenses at
Electronics Goldmine
Figured they were worth a shot for $5. I'll let you know what's what when they arrive.
Alright, so I'm waiting on my new lens with auto-iris to come.
Then I remember that giant compustar lens I have. I went to hook it up and apparently had the wrong datasheet. This lens has it's own iris circuitry built in instead of the camera driving the iris directly. So you feed it power and video and adjust the knob to determine compensation (anywhere between peak and average intensity.)
What a difference. Here's two short (~500k) videos showing the iris turning on. This lense is F1.2 so the blinding effects are even more noticable than with the other cams. As you can see, the pics with the iris fully open are fairly useless. As an aside, the lamp is not that bright, those bulbs are only 15w.
vid 1
vid 2
So if the iris of the new lens being driven by the camera is similar, then that and a polarizer should be a giant improvment.
update
As an aside, when I was testing this earlier looking outside, I shut off all the lights (to kill the reflection on the window) and while toggling the iris, a alligator clip came loose and shorted something. Only I didn't know it.
In short order, the picture went out, then in the dark I saw little blue sparks and then the wires start to burn. I fumbled for the plug in the dark and yanked.
My camcorder was unscathed, but judging by the smell and scorch mark on the board of the nitemax, figured the nitemax, and probably the electronics of the auto-iris lens were toast.
Everything survived, let's hear it for good engineering.
lol don't you hate it when little aligator clips slide off.
