Page 26 of 70 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 695
Thread: Project NiteVision - NiteMax + HUD + carputer
  1. #251
    Raw Wave tj!2k4's Avatar
    Oct 2004
    How about using a replacement PSP screen.. seems they can be had for ~$50..?
  2. #252
    Aug 2005
    In the new episode of Top Gear Jeremy takes a look at some in car night vision systems.
  3. #253
    May 2006
    I wonder if you could replace the factory VFD with the little LCD in the 'Vette projector? Looks like these folks are not having the double-image problem...maybe they just polarize all the Vette windshields from 97 on...
    $385 isn't cheap, but if it worked, it wouldn't be bad.
    http://forums.corvetteforum.com/show....php?t=1382686
  4. #254
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Got the DC Auto Iris lens working. Actually I did this last week, but it wasn't working right. I'll have to double check, either one of the pin outs were wrong, or I had it backwards in the socket. Either way, I just flipped it around and it works.
    Same one as this.
    Cheap and adjustable. Getting auto iris to work sucked though. The connectors and solder pads are so damn small.
    I couldn't manage to get wires soldered to it, so I ended up unsoldering the tiny feature connector (think it's a molex picofuse) and carefully soldering the 4 leads to it. On the other end, I used a 2x2 molex header to connect to the auto-iris plug. It's a little snug but it worked.
    Unfortunately the lens is a lot taller than the old one, but it's a usually image.
    I ordered some picoblade "pins", I think it would be easier to crimp them on some 30ga wire and then just push it over the pin. I'll let you know when i try it. That way less risk of breaking something.
    Try and take the car out for a spin and get some night video later.
  5. #255
    May 2006
    Genesisfactor
    Do you know how to contact Mark? I sent him a PM few days ago and haven’t received reply yet. Thanks
  6. #256
    Mar 2005
    NY
    For now, you don't, He's out of town. I forgot when he said he'd be back. Sorry! Hehe, apparently, i took a page out of his book and was out of contact almost all week:P...
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  7. #257
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    @shotgunefx How is the auto iris lens working? does it compensate for the glare of other cars lights in the night? Could you share the pinout BTW. I think I will order one very soon. The glare is really killing me at night.
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  8. #258
    Apr 2005
    Boston, MA
    Quote Originally Posted by spaceskater
    It was working fine, haven't put it in the car yet.
    Rather I was going to, but I broke one of the wires, no big deal, but I can't find my molex KK pins amongst all my crap.
    I'm digging for them now so I can install it and take some vid tonight.
    In testing in the house, the iris worked pretty well. I'm just hoping it doesn't dim it to much on the street. I don't think it will as unlike my test, the headlight won't be trained on the lens.
    The pinout on the camera side for the DC Iris is in the main nightmax thread here.
    The lens comes with a sheet that tells you what pins are what.
    You have one of the UltraCCDs correct? The regular nitemax board is different. Not even sure if it can drive an iris lens.
  9. #259
    Apr 2005
    Boston, MA
    I'm about to say **** it.
    I find my molex tool and crimp pins and as I'm about to do the last one, one of the wires soldered to the board breaks.
    I'm not soldering these again. They solder pads are so friggin close together (~0.015") under the header and my hands shake like a freaking vibrator.
    [img]http://www.leeland.net/lib/leeland/****ingccd2.jpg[/img]
    I'd try another CCD with the header intact and those picoblade crimps I ordered, but no they ******* disappeared.
    Just had to vent.
  10. #260
    Aug 2005
    I hear you brother I always have moments like those when messing with projects. Whether working on my car, gun, or some sort of electronics it never fails, something stupid happens and makes me want to take a hammer to it. Keep with it though, and it'll work out in the end. You've done some great work so far and now you need to put it all together.
  1. PROJECT: 2004 Xterra Carputer
    By elgenyo in forum Fabrication
    Last Post: 06-01-2007, 04:23 PM
  2. VW Golf mk3 - carputer project
    By Sh0cker in forum Show off your project
    Last Post: 12-09-2005, 10:14 AM
  3. My Carputer Project, need advice
    By natesimpson74 in forum General Hardware Discussion
    Last Post: 09-21-2005, 01:14 AM
  4. My carputer project: Solaslim
    By nthai in forum Show off your project
    Last Post: 10-28-2003, 03:43 PM
  5. New CarPuter Project: Need Input!
    By Tremek in forum General Hardware Discussion
    Last Post: 01-31-2002, 03:07 AM
