I don't really have a setup per se. I've just been trying different things to find something workable.Originally Posted by jammy_basturd
A few setups I've experimented with...
LCD on dash reflecting onto collimnator
LCD projected through projected lens
Viewfinder CRT projected.
It's worse than a double image. The projection source is a lot brighter than the image. So you see an image and then a comparatively sun-like object (the lens) on the screen. Had the same problem when trying to project the lcd only worse as it was a much bigger lens.
I'm sure you've come across projectors in person (slide,film,etc). Picture looking into where the image comes out and how bright it is. That's what's showing up.
LinkBack URL
About LinkBacks
