Page 41 of 70 FirstFirst ... 313233343536373839404142434445464748495051 ... LastLast
Results 401 to 410 of 695
Thread: Project NiteVision - NiteMax + HUD + carputer
  1. #401
    Mar 2005
    NY
    i want to know what film they used. the double image was our biggest problem and it seems to solve that.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  2. #402
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    Quote Originally Posted by Genesisfactor View Post
    sounds like mirror tint. or something very similar.
    PC Components:
    My work log
  3. #403
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    mild mirror tint is what they used, like i said since led's are bright they don't need anything strong, for lcd, we will need darker mirrow tint
    Yev
    R. T. F. M
  4. #404
    Mar 2005
    NY
    ah i see, i was just curious on how they managed it.
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  5. #405
    Sep 2005
  6. #406
    Mar 2005
    NY
    Quote Originally Posted by alpha_maverick View Post
    that being MY worklog...
    ...and linked to in my sig...
    I think its a well written piece of work on a promising idea that is only not executed due to the loss of the car. The individual has some interesting ideas on a modular design and news to get ovver his accident induced ADHD and other newfound cognitive disorders to get his act together and finish his HUD, get the voice control on the AI and HTPC and PPC working properly, get the UI right
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  7. #407
    Sep 2005
    sorry, wrong link. I feel like an idiot. I am using Linux, so I just middle-clicked, thinking that this was the last thing I had highlighted.
    in it, it says it uses 50/50 reflective combiner. I am pretty sure that this is the only way to get rid of the ghost image.
    in order to get it to focus at some arbitrary distance, I believe that 3 lenses are required. set the assembly focal point to near the drivers head (after reflection) and fine tune it to get the apparent distance you want.
    I am in the process of a motor swap, so I do not have the funds to attempt this right now, but I am fairly certain that it will work.
  8. #408
    Mar 2005
    NY
    That is defintiely more interesting than your last link . dont' worry we all make mistakes. If you can research this 50/50 combiner, that would be cool!
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  9. #409
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I don't think it's just a 50/50 "two way" mirror (which I'm planning to buy for experimenting btw), they use it for teleprompters, and samples are available on ebay cheap. I think under 10 bucks. Just search for "two way mirror" and you'll find the seller.
    A few problems I see with the type of pictured system, it's big, in a passenger car, would most likely be a big hazard to someone's skull mounted on the ceiling.
    You'll also have what amounts to a extremely bright flashlight shooting out of the windshield. Not a problem for the military, but for street use, I think it would get you lot's of unwanted attention.
    I really think the only way you can project a hud on a budget (as opposed to reflecting one, which isn't such a bad idea and it's easy) is to oriented it such that the light source isn't viewable from your position, (ie from near the bottom) but then you have to worry about the image being distorted.
    Though that would be an easier thing to work around. You'd basically have to scale the scanlines smaller as you reached the top of the screen. But at least the transorm is linear and there are plenty of optimized algorithims for scaling scanline "textures". I'm certain almost all gpus are optimized for this nowadays.
    If you were using something like OpenGL or D3D, you could just paint the image frame on a plane and tilt it away from you.
  10. #410
    Sep 2005
    a combiner is the same as a beamsplitter. 50/50 means that 1/2 is reflected and half is allowed to pass through. some are directional, meaning that from one direction, nothing (not much) is reflected, but from the other side, it's half and half. http://www.edmundoptics.com/onlineca...productid=2035
    Reflected and projected are the same thing!!!! you are not focusing the image on the plate! you focus it on your retina (or near it)! you align the optics to reflect the light so that it is (relatively) square to your eye-level and adjust the focus so that the image appears at the end of the hood, etc. kinda like the focus knob of binoculars.
    GTG, more later
  1. PROJECT: 2004 Xterra Carputer
    By elgenyo in forum Fabrication
    Last Post: 06-01-2007, 04:23 PM
  2. VW Golf mk3 - carputer project
    By Sh0cker in forum Show off your project
    Last Post: 12-09-2005, 10:14 AM
  3. My Carputer Project, need advice
    By natesimpson74 in forum General Hardware Discussion
    Last Post: 09-21-2005, 01:14 AM
  4. My carputer project: Solaslim
    By nthai in forum Show off your project
    Last Post: 10-28-2003, 03:43 PM
  5. New CarPuter Project: Need Input!
    By Tremek in forum General Hardware Discussion
    Last Post: 01-31-2002, 03:07 AM
