Page 6 of 70 FirstFirst 1234567891011121314151656 ... LastLast
Results 51 to 60 of 695
Thread: Project NiteVision - NiteMax + HUD + carputer
  1. #51
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Hey guys.....what about a small piece of window tint? If anyone has any laying around, give it a try. That might help block light coming from outside of the car (other car's headlights, streetlights) while providing a dark background to project on.
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
  2. #52
    FLAC sama's Avatar
    Feb 2006
    London, UK
    sorry, don't mean to be anal but it's to reflect on
    does anyone know if it's legal to tint the windsheild in teh uk?
  3. #53
    FLAC alti's Avatar
    NY
    As far as I know it is not legel to tint it in the us, no idea about the uk, when does it become a projection as opposed to flecting on the glass? does the addition of a lens make the difference? Or is it because there is a reflective quality to the glass, rather then a screen that is not reflective?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #54
    FLAC alti's Avatar
    NY
    Quote Originally Posted by SnyperBob
    that was one of my original ideas ,and i think it will be the easist most practical solution. I have to get to the autoparts store and pick some up....
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  5. #55
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    @alti: I use a thin piece of plastic i cut from a packaging. Because it is thin i don't have the double image problem. In the first image i use the same thing in front of the instrument cluster window and the first image is VERY sharp. I was thinking of using a 5" LCD for that since the 2.3" of my PDA does seem very small. In the first two photos u can see what i used to reflect the nice sharp image on, the third is a piece of plexi I used and u can see it is thick so I got the double image problem on it. if i can find something more reflective and thin then maybe it will work better. I'm thinking of going by Auto Zone to get some window tint.
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  6. #56
    Apr 2006
    window tint should work well, i dont think it would be illegal as you are only tinting a small section.
    example
  7. #57
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Wink
    Here in the US it is illegal to put anything in the front view. You can't even have anything hanging from the review mirror because of obstructions of view. They can even give you a ticket for a cracked windshield, but check out the new Corvette, they have this **** build in. Would be good to research this.
    Here is a Quote from a Glass Manufacturer.
    What makes the HUD glass different from standard glass?
    All USA DOT approved windshield glass is a composite with a thin plastic layer between an inner and outer layer of glass. HUD glass has a special thin transparent laminate between the glass in the projection area. This laminate is manufactured specifically for the HUD and has different reflective properties and is more consistent in its density than the standard windshield laminate.
    On some early factory HUD glass there is a rectangular area visible in the glass, at some point GM changed design and you can not see the HUD reflection area outlined in the glass with the car off.
    Our aftermarket HUD glass is the same as the later GM design in which the outline of the HUD reflection area is not visable with the car off.
  8. #58
  9. #59
    Newbie kornkow's Avatar
    Jan 2006
    Maryland
    the new corvette isnt the only one. the grand prix gtps have had HUD's for at least 10 years. the bonnies have them too. I was going to take a look at how my HUD was constructed, but i think itll be a while til i have enough time.
  10. #60
    Feb 2005
    Boston,MA
    Quote Originally Posted by MGD
    MGD what company makes aftermarket HUD windshields? Wher did u get that?
  1. PROJECT: 2004 Xterra Carputer
    By elgenyo in forum Fabrication
    Last Post: 06-01-2007, 04:23 PM
  2. VW Golf mk3 - carputer project
    By Sh0cker in forum Show off your project
    Last Post: 12-09-2005, 10:14 AM
  3. My Carputer Project, need advice
    By natesimpson74 in forum General Hardware Discussion
    Last Post: 09-21-2005, 01:14 AM
  4. My carputer project: Solaslim
    By nthai in forum Show off your project
    Last Post: 10-28-2003, 03:43 PM
  5. New CarPuter Project: Need Input!
    By Tremek in forum General Hardware Discussion
    Last Post: 01-31-2002, 03:07 AM
