Page 8 of 70 FirstFirst 12345678910111213141516171858 ... LastLast
Results 71 to 80 of 695
Thread: Project NiteVision - NiteMax + HUD + carputer
  1. #71
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by alpha_maverick
    here's a thought: use a thin, clear, reflective piece of plastic to reflect the image, and put the privacy film (polarizer) behind it, up-down polarized, and the light will not be reflected off of the windshield, but off the plastic. Somebody try this?
    I think it would work fine (which is what I was getting at with the above FYI ), it's just what I had on hand. Actually before I went cut out the two pieces, I was using a CD case and that worked fine for a reflector.
  2. #72
    Sep 2005
    Oh. OK, cool!
    More pix!
    BTW, where did you find your avatar?
  3. #73
    Apr 2005
    Boston, MA
    Quote Originally Posted by Genesisfactor
    No, shotgun, i thnk, wihtout a doubt, thats' the most ingenius idea ever...i'm hoping we can get a clear polarized film or something. As for those magnifiers, link me. I think i'm using a 7" instead, but fpr the gauge cluster, this woudl rock
    As for holding three things up, you got Jedi powers, use em! That or your feet no excuses!
    Links....
    "Heads Up Glass"
    http://www.goldmine-elec-products.co...?number=G13586
    "Deluxe Backlight Panel"
    http://www.goldmine-elec-products.co...p?number=G9620
    Some of the films might come in handy, at the worst, you can use the diffuser for your own backlight projects. For 8 bucks, worth a try.
    For the magnifier, just hit ebay and look for "Gameboy Advance Magnifier" and you'll get tons of hits.
  4. #74
    Apr 2005
    Boston, MA
    Oh. OK, cool!
    More pix!
    In my room
  5. #75
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    Well I think I found the solution to our problems!!! I did sone resherch on LCD and polarization and as I remembered LCD light is polarized. So if we just put a completely clear piece of polarized filter on the windshield exactly where the HUD should be then the light of the LCD will be completely reflected by the polarized film. It will never reach the glass of the windshield so no double image or any thing AND since light outside is NOT polarized it will go through the film with no problem! In addition during daylight the film Acts like a pair of polarized sunglasses!! it only blocks glare reflected from ground!!! You can cover all the driver side of the windshield so no seams visible and the LCD will practically be invisible to the outside!!! i did a proof of concept using one striped nitemax LCD as a polarized filter! Look at photos! First two just demonstrating the ability of the filter in front of my monitor. Third photo: I use the LCD in the middle but turned side ways so it is not blocking light. so u can still See a faded reflection behind it in the piece of clear plastic. In the forth photo i have the LCD blocking the light so u can see NO reflection in the back!!! last photo is just so you can see what I am doing. BTW at that point I wish I had two more hands or maybe be a Jedi!!! Cant hold all these things straight and take a picture too...
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  6. #76
    Feb 2005
    Boston,MA
    Now the big question! where do we get a completely clear polarized film???
  7. #77
    Apr 2005
    Boston, MA
    One problem I see for some people (like myself) with just putting film on the window is the shape of the windshield. Mine curves quite a bit and would cause a lot of distortion.
  8. #78
    Sep 2005
    http://www.edmundoptics.com/onlineca...=2035&search=1
    If a beamsplitter is used "backwards" it should combine the two images, resulting in a HUD that is transparent, yet reflective
    now looking for a coating for those of us with a (relatively) flat windshield
  9. #79
    Jul 2001
    Quote Originally Posted by shotgunefx
    Ever seen a Corvette windshield? They're ridiculously curved.
  10. #80
    Sep 2005
    curve can be compensated for with a cylindrical lens/mirror
    edit: still looking for coatings
  1. PROJECT: 2004 Xterra Carputer
    By elgenyo in forum Fabrication
    Last Post: 06-01-2007, 04:23 PM
  2. VW Golf mk3 - carputer project
    By Sh0cker in forum Show off your project
    Last Post: 12-09-2005, 10:14 AM
  3. My Carputer Project, need advice
    By natesimpson74 in forum General Hardware Discussion
    Last Post: 09-21-2005, 01:14 AM
  4. My carputer project: Solaslim
    By nthai in forum Show off your project
    Last Post: 10-28-2003, 03:43 PM
  5. New CarPuter Project: Need Input!
    By Tremek in forum General Hardware Discussion
    Last Post: 01-31-2002, 03:07 AM
