Anytime you interfere with the fueling system such as the fuel pump circuit with the motor running, you risk the chance of leaning out the mix for a duration long enough to cause detonation. The fuel pump voltage supply is also very dependent on wire conductance, and placing a typical relay with its low rated contacts within this circuit can degrade a motors performance.
Our systems can automatically flash GM OBD-1 powertrain controllers with code that prevents the vehicle from starting, in addition to other modes such as valet, performance, economy, etc. It is impossible for anyone to physically bypass a PCM code flash.
