Assuming the FET switches off, the circuit floats the ground input of the regulator. This causes the regulator output voltage to approach the unregulated input voltage. Subsequently re-attaching the regulator ground (i.e. turning on the FET) can damage the regulator. Check the regulator datasheet for an example.
LinkBack URL
About LinkBacks
