Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: General circuit reverse engineering section
  1. #21
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    Well, back to your original question... overpowering the address bus ~probably~ doesn't cause things to explode. I remember reading about a gizmo called something like the python that used a bunch of paralleled chips to override the address bus so the memory of a computer running copyprotected games could be dumped. This would have been in the Apple ][ days.
    Then again, who else would be driving the address pins but the microprocessor? So it really should be safe.
  2. #22
    Sep 2006
    Hello,
    I think that it is enough to put 8K resistor to the ground on that pin (without soldering).
  3. #23
    Sep 2006
    Quote Originally Posted by waldi View Post
    Hello,
    I have used 8K resistor to enter bootstrap mode and then I have read all memory data.
  4. #24
    Feb 2007
    Macclesfield, UK
    Smile
    Colin Bourassa emailed me. Anybody need any help delving into the Audi S4 ECU?
    Andy
  5. #25
    Mar 2004
    Vancouver, BC, Canada
    If anyone finds this old thread, I've moved my work to www.nefmoto.com
  6. #26
    Mar 2006
    Colorado, but Canadian!
    Why not post the cool bits here too?
    1.9in x 2.9in -- 47mm x 73mm
  7. #27
    Raw Wave
    Nov 2009
    Anyone into the Delco stuff?
    Or any good Delco (RE) sites
  8. #28
    Mar 2004
    Quote Originally Posted by 2k1Toaster View Post
    Because I have an entire website full of cool bits.
  9. #29
    Newbie Ydef's Avatar
    Mar 2007
    Seattle
    Lightbulb
    Quote Originally Posted by archimense View Post
    Hi Archimense,
    This thread has totally piqued my interest. I've been searching high and low for ways to do an audi ecu flash via obd-ii cable if possible.
    But the link you provided nefmoto.com appears non-functional.
    Did you misspell it? Thanks for your follow-up on a four year old topic regardless.
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 04:43 PM
  2. Reverse engineering cam file...Proposal for $$
    By RoyN in forum Software & Software Development
    Last Post: 10-20-2005, 01:54 PM
  3. Motor circuit with reverse
    By freestyler in forum Hardware Development
    Last Post: 08-25-2005, 01:44 PM
  4. Help with on/off circuit for Mobo
    By powerslide in forum General Hardware Discussion
    Last Post: 08-16-2004, 01:48 AM
  5. reverse engineering of cd-changer interface
    By sulten in forum General Hardware Discussion
    Last Post: 01-13-2000, 11:36 PM
