Results 1 to 10 of 10
Thread: help with micro switch
    Apr 2005
    I have a IBM latop in a mini dock, docking station.
    I though I could just wire up an extension into the on/Off switch on the docking station.
    But when I opened it up the on/off button push against a rod that extend down to the main circuit board where there is a tiny switch.
    anyways, I can solder, no problem, BUT the little switch has 5 leads coming out off it!?!?!
    one side has 3 and the other side has 2.
    anyone know why the switch would need 5 leads??
    and switch 2 do I need to solder to turn it on??
    thanks
    Apr 2005
    The top right pin has the word "SW1" near it, so I'm guessing that's one of them, still need to find the matching pin for that
    Oct 2004
    NY
    more than likely there is still only 2 that need momentary contact with each other
    to start it..... picture?
    Oct 2004
    NY
    ahh, pictures...
    just test the 4 corner ones.... pick one, then touch it with a jumper to one of the others..... continue until it starts..... those are them....
    May 2005
    Often times there are redundant leads on surface mount tact switches like the one in the picture. Looks at the traces on the PCB and see where they go. You will see that that there are only two different traces leading away from the switch. They usually have 4 leads. I have never seen one with 5. Maybie there are two common pins, a normally open and a normally closed.
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    Try measuring between the different leads with a voltmeter. If you find a voltage, keep the leads connected and push the button, and see if the voltage goes to zero when the button is pressed.
    Apr 2005
    Quote Originally Posted by BassBinDevil
    Shouldn't voltage only go throught when the button is pressed??
    finally found my volt meter
    OK, I've found that when I have connectors on
    the top left and bottom right pins AND the button is pushed I get connectivity.
    (when the button is released, connectivity is broken)
    On the other hand, without holding down the button
    I only get connevtivity on the Top left and Top right pins
    BUT there is NO change if the button is pushed......
    Right now I'm guessing I should use the first scenerio, right?
    Oct 2004
    NY
    dude, it really is as simple as test jumping one by one to see which one fires it
    Apr 2005
    Quote Originally Posted by turbocad6
    yeah, I just don't wanna fry the board (it's happened before in the past )
    I'll give that a try tomorrow, time for some sleep
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Check out my sig as well. Lots of good info from numerous users. Covers this a few times. Laptop Power On Module
  1. Remote On/OF Switch for an Inverter
    By PapaPrem in forum Newbie
    Last Post: 03-09-2005, 10:54 AM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 10:51 AM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
  5. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 01:13 AM
