+ Reply to Thread
Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 94
Thread: Another USB relay controller
  1. #11
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Rickertsen2
    Here are some pics of the board i made:
    The top
    http://geargrinders.net/james/usbr/s001.JPG
    The bottom
    http://geargrinders.net/james/usbr/s002.JPG
    Sweet, that should be easy enough to solder and with the directions you gave for making the board this should work great.
    lol I'll just have to rely on the rest of you guys for the software side
    I just noticed too, your board/circuit gives the option of normally open or normally closed for the relays. That is sweet, since the few other usb relay boards I've seen are one or the other.
  2. #12
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It turns out, making a board isn't as hard as it sounds. I found a method that is pretty easy. It doesn't look like it should work well, but in actuality works awesome. I found it Here. I will summarize the process.
    I used that Staples paper and Lazer Toner transfer to build the PCB for the Sproggy PSU.
    It came out really clean
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #13
    Oct 2002
    Have you calculated the trace widths required for the 15amps?
    many board houses also do small production runs.
    Microchip also have a small scale pre programming service.
  4. #14
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Have you looked at http://www.expresspcb.com ?
    A good alternative if you don't have the time to learn eagle. It looks like you might be able to fit in on a mini-board. If so, 3 for $51.
    I've used their service and was quite happy.
    Here's a pic of the rgb led driver boards I made. I had to pack it damn tight though.
  5. #15
    May 2005
    Thanks for you interst everyone.
    I got the parts today and assembled them (mostly). The USB connector is lying beside the board, because i routed the traces wrong, and most of the connectors are missing because DigiKey sent me the wrong thing.
    Here are some pics:
    The top
    The bottom with the SMD components.
    I tested all the hardware and it seems to work. Time to get programming!
    Quote Originally Posted by davesaudio2
    I did not do the calculations but it is something i am thinking about. As you can see in the pics, the power traces are covered in a thick layer of solder which makes up most of the cross sectional area. If/when it ever goes into or a kit or production, i will fill all the available space. What i really need to know is what kind of volume small kits like this are usually produced in. I figure I would need at least 10 to make a kit for mp3car people worthwile and at least 100-500 to make an assembled product. Relay boards are useful to more than just carputer people.
    btw shotgunefx, that RGB driver is pretty sweet. I've been contemplating a similar project.
  6. #16
    Low Bitrate LowLux's Avatar
    Oct 2005
    Qld, Australia
    any updates?
  7. #17
    Registered User
    May 2003
    Just out of interest, have you tried turning the relays on all at the same time?
    Depending on the relay coils consumption and USB current output, this may bring down the USB power rail.
  8. #18
    May 2005
    Quote Originally Posted by LowLux
    any updates?
    I havn't had time to work on it since i posted the last pics. I'm going to start writing some code for it once i finish this post. I'll keep everybody informed.
    Quote Originally Posted by Chris31
    The usb power specifications were taken into consideration during the design. It should draw less than 500ma (the USB max) at all times even with all relays engaged, the microcontroller running under normal conditions and the LED on.
  9. #19
    Sep 2005
    I got this from the ExpressPCB site, i use it to do my trace sizing and its never burnt out any boards yet
    Traces that carry significant current should be wider than signal traces. The table below gives rough guidelines of how wide to make a trace for a given amount of current.
    0.010" 0.3 Amps
    0.015" 0.4 Amps
    0.020" 0.7 Amps
    0.025" 1.0 Amps
    0.050" 2.0 Amps
    0.100" 4.0 Amps
    0.150" 6.0 Amps
  10. #20
    Oct 2002
+ Reply to Thread
  1. USB Relay Controller - Test software.
    By Zac in forum Hardware Development
    Last Post: 10-02-2005, 04:08 AM
  2. WTB: psu, su/sd controller, and USB dvd
    By Journer in forum Classified Archive
    Last Post: 08-08-2005, 12:41 PM
  3. Serial Relay Controller
    By lifeboat in forum General Hardware Discussion
    Last Post: 06-29-2005, 03:55 AM
  4. WTB: Opus 120-150, DSSC controller, ITPS, USB TV, 256 Memory
    By clean customs in forum Classified Archive
    Last Post: 03-21-2005, 05:47 AM
  5. 7" touch overlays with usb controller any interest
    By pogue1000 in forum LCD/Display
    Last Post: 01-14-2004, 03:35 PM
