Page 1 of 10 12345678910 LastLast
Results 1 to 10 of 94
Thread: Another USB relay controller
    May 2005
    I'm working on another USB relay controller. It will be 5 channels of 15A SPDT relays and will be bus powered, meaning no 12v connections necessary. I have a board made so far(sorry no pics) and am waiting to get my hands on the parts. From there i will write the code, and when i am done, i will create some instruction on how you can make your own. All the parts are about half the price of a phidget, but you must not be afraid of soldering (including SMD parts) and making your own circuit board. I may look into making a kit which is something i know zero about.
    Code:
    U S B   5 c h   S P D T   R e l a y   c o n t r o l l e r   B O M
    Desc				Subtotal	Qty	Digi-Key
    PIC18F2450-I/SP			$6.53		1	PIC18F2450-I/SP-ND
    USB conn			$1.92		1	WM17113-ND
    Circuit Board 3x4.5		$4.60		1	PC51-ND
    MRA4003T3G Diodes		$0.26		10	MRA4003T3OSCT-ND
    TRANSISTOR NPN 50V 0.5A SOT-23	$2.31		7	497-2531-1-ND
    10K resistors			$0.88		10	311-10.0KFRCT-ND
    470 Ohm resistors		$0.88		10	311-330FRCT-ND
    3 pin terminal block 5.08mm	$0.98		1	281-1436-ND
    12 pin terminal block 5.08mm	$3.86		1	281-1441-ND
    Resonator 4.00MHZ Ceramic w/cap	$0.54		1	X902-ND
    relay				$6.00		5	255-1103-ND
    28 pin DIP socket		$0.34		1	AE8928
    LED T1/2					1
    CAP CER 1.0UF 10V 10% X7R 1206	$2.64		10	490-1800-1-ND
    T o t a l:			$31.74
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    sweetness... subscribed
    keep us informed. I've no problem soldering, though the board making might get me.. lol but I'm willing to give it a go. That's way cheaper than anything else I've seen.
    May 2005
    Quote Originally Posted by W3bMa5t3r
    If there is demand i can probably make a kit with a premade PCB available. I would really like to make a fully assembled product, but i don't know anything about the process.
    It turns out, making a board isn't as hard as it sounds. I found a method that is pretty easy. It doesn't look like it should work well, but in actuality works awesome. I found it Here. I will summarize the process.
    1.) Print out the pattern onto Inkjet Photo Paper using a Laser printer. If you are like me and don't have a laser printer, then print it out on photo paper(for quality), take it to Office Depot, Kinkos, etc and use their laser copier, to copy the artwork onto the inkjet photo paper. I have tried two different brands of paper, one works better than the other, but both work well.
    2.) Prepare the PCB by cleaning it off well. You may want to use some high grit sandpaper like 1000 grit or whatever to get the dirt and oxidation off. Alternately, i had some stainless steel cleaner lying around that brightened it right up on contact. Just for good measure, i went over it with some rubbing alcahol.
    3.) Cut out the pattern and iron it on to the board. Use the hottest setting you have along with plenty of pressure, and take your time, The paper will stick to the circuit board and so will the ink. TAKE YOUR TIME. You cannot use too much heat, too much pressure or too much time. This is the most critical step of the process, but it is not hard if you take your time and work the whole thing over thoroughly.
    4.)You now have a blank circuit board with a piece of paper stuck to it. Run it under warm water and carefully peel off the paper. This will not happen cleanly and will take some work. using your fingers, a rag or whatever else, remove all fragments of the paper. The ink is fused to the board, but it is not impenatrable. Care must be taken to scratch/pull off all the paper without damaging the ink. Paper left over the ink is ok, but make sure there is none anywhere else.
    5.)Now it is time to etch the board. If you have screwed up before this point, you can use some acetone to clean off the entire board and start over. Soak the board in tray of Ferric Chloride (available at many radio shack's) until all the copper except that covered up by the ink is eaten away. DO NOT do this in anything metal. This stuff will screw up anything metal. Do not pour it down your nice stainless sink, it will screw that up too. The etching will take awile. Monitor the process stirring occationally. If you can heat up the solution, the process will go a little quicker. For my board it took about half an hour.
    6.) When the board is finished, rinse it off. Use Acetone to clean the ink off leaving you with a nice shiny board.
    7.) drill the holes. You will need REALLY small drillbits. I got mine from http://www.store.yahoo.com/drillcity/10pac8503new.html. It says they are for drilling propane orfices, but one the package they say they are for drilling PCBs. You are done.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    keep up the good work. am watching
    what code language are you gonna use?
    Apr 2006
    Washington, DC
    Yeah, I saw some of the products at the Rad Shack for doing this, but I wasn't tooo sure I wanted to try it, but you make it sound easy enough. Are you using a single or double sided copper clad board? Does the IC have to be programmed, and if so, will you be doing that as part of providing the kit? Also, what do I print out? One of the pics you have posted above? Thanks :-)
    May 2005
    Quote Originally Posted by Scouse Monkey
    The actual PIC chip will be programmed in C. On the computer side, i'm not sure yet. I'm thinking i will provide examples of how to talk to it in C++, VB and maybie JAVA. What do yall want?
    After much work, i figured out how to do it on a single sided board with only 1 jumper wire. This is the first PCB i have made myself and i was a little weary to try double sided right off the bat as you have to get both sides aligned pretty perfectly. There are through hole parts on the top of the board, and then some surface mount stuff on the bottom.
    Yes, it does have to be programmed. If i provide a kit, i will program it.
    I'll post another image of what you need to print out once i get everything working which will hopefully be fairly soon.
    Apr 2006
    Washington, DC
    Quote Originally Posted by Rickertsen2
    As far as the programing side goes, I've no clue, so I'm out on that one. Single sided board with only one jumper will work for me. :-) SMT and all are good too. I also don't have a way to program the chip, so if you provided a kit that would be AWESOME!! :-) Just let us know when it's all good to go and thanks
    Mar 2004
    Bristol
    VB and c++ are perfect for me.
    edit: an i know people who can do java so your heading the right way if you do a mix or just one. VB would probably be the most universal though. I would see what the RR and CF people would prefer as getting frontend support would be awesome.
    May 2005
    Here are some pics of the board i made:
    The top
    http://geargrinders.net/james/usbr/s001.JPG
    The bottom
    http://geargrinders.net/james/usbr/s002.JPG
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    VB would definately be a good thing
  1. USB Relay Controller - Test software.
    By Zac in forum Hardware Development
    Last Post: 10-02-2005, 04:08 AM
  2. WTB: psu, su/sd controller, and USB dvd
    By Journer in forum Classified Archive
    Last Post: 08-08-2005, 12:41 PM
  3. Serial Relay Controller
    By lifeboat in forum General Hardware Discussion
    Last Post: 06-29-2005, 03:55 AM
  4. WTB: Opus 120-150, DSSC controller, ITPS, USB TV, 256 Memory
    By clean customs in forum Classified Archive
    Last Post: 03-21-2005, 05:47 AM
  5. 7" touch overlays with usb controller any interest
    By pogue1000 in forum LCD/Display
    Last Post: 01-14-2004, 03:35 PM
