Results 1 to 10 of 11
Thread: Linear Actuator vs Motor/Servo
    Constant Bitrate bl3nd3r's Avatar
    Jun 2006
    Pickering, Ontario, Canada
    I am wondering what would be a better idea for tilting a screen in a custom enclosure. If you check out this diagram it shows either a motor with a gear or a small linear actuator. (The pink thing is the screen)
    From experience which would be more expensive? What would be the most reliable and have the best operation? Also what is the main difference between a servo and a regular motor?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by kmstech
    Actuators are very expensive.
    Servos and Steppers and DC motors are cheap in comparison. Steppers and Servos need some sort of control.
    You should do some searching on this board, since this has been covered several times.
    There is currently a double din enclosure being discussed.
    Michael
    Low Bitrate slantman's Avatar
    Apr 2005
    north augusta SC
    you might find what your looking for here http://www.mpja.com/ they are very cheap
    Oct 2004
    NY
    dude, before you even figure out how to move what it is you want to move, you have to actually build it & build sliders, tracks..... you should be able to build it complete, then figure out the best way to add motorization..... whether you use a motor/gear or actuator doesn't matter at this point......
    you've got enough ahead of you to figure all the rest out & get it working before thinking about adding motorization....
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Quote Originally Posted by slantman
    I looked into the MPJA one when I was researching my motorized setup. It's very very slow. I don't have the calculations anymore, but I remember it was something like 5 seconds to fully deploy with the fastest servo controller I can find. Doesn't sound like much, but after running a few simulations, it was just too damn slow for me. I'd rather it deploy in 2 seconds or less.
    edit: oh, by deploy i mean extend/retract 4.5 inches.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Jun 2006
    I am working on the CAD drawings right now for the actual enclosure and to build my first prototype.
    Right now I have a couple phidget usb servo controllers on order and am wondering if they will be able to control motors if i decide against using servos.
    Also what is the actual size of a double din frame? I have seen a few different measurements but most are saying 7in x 4in. However if you look here you will see that it says the dimensions are 7-1/8in x 4in.
    Dec 2005
    you might be able to use the CD drive mechanism from old drive. Its 5V dc so no stepper driver is required.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    With a CD drive mechanicsm though, you are going to be limited by the original travel distance of the drive. They only have something like a 3" of travel. Unless you add your own mechanism.
    They do sell linear servos though. They use them in planes, or sailboats I think. I know they exist, I have no idea how much they cost.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    The land of polar bears and nekkid blonds
    My original plan, using flat wing servos and a USB servo controller.
    Jun 2006
    Maximus I like your idea. I am building part of the box today and I get my USB servo controllers tommorow so I should be ready to test out different things over the next week or so. I will definitely keep you posted. Thanks for the drawing though
  1. Linear Actuator?
    By kickercivic1 in forum Off Topic
    Last Post: 11-30-2007, 03:47 PM
  2. 4 inch Linear actuators
    By Lando in forum General Hardware Discussion
    Last Post: 05-22-2005, 12:57 PM
  3. Volume % is linear, not tapered
    By wysocki in forum FrodoPlayer
    Last Post: 01-19-2005, 08:33 PM
  4. Who knows something about linear actuators?
    By SuperMatty in forum Off Topic
    Last Post: 05-06-2003, 04:22 PM
  5. Anyone try linear regulators?
    By eugenen in forum Power Supplies
    Last Post: 05-30-2002, 10:40 AM
