Results 1 to 3 of 3
Thread: USB primer request
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    USB primer request
    I know next to nothing about USB, and was wondering if anyone could enlighten me on a few points.
    I understand that USB is a data transfer protocol to allow high-speed interaction from 1 device to another.
    The reason I ask is that I found a device that has a USB port, and want to talk to it. The manufacturer says it's not a good idea, but that just eggs me on. The device will accept a memory stick with MP3s, and play them. I want to be able to hook in w/a laptop and control it.
    Would I need some dort of driver to communicate with it, and if so, is it possible to write a driver via reverse-engineering (since the mfgr most likely will not write one)?
    Here's a thread to more info on the device, a Dension ice>Link Gateway 500.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    FLAC jbors's Avatar
    Nov 2003
    You cannot connect this device directly to a PC as they both use USB Host controllers. In USB one side should be host and another slave to work.
    Car pc integration with ease
    Car mediacenter
    Jul 2005
    Motor City
    Ah. Thank you jbors. Do you think there is a way to make the laptop an "active slave" As in, be a slave, but simply listen for and interpret commands given by the host?
  1. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. USB2.0 hub don't go full speed in XP
    By Gredd in forum General Hardware Discussion
    Last Post: 07-24-2005, 11:31 AM
  4. USB power issues - opinions please
    By zaxxon in forum Power Supplies
    Last Post: 07-20-2005, 11:03 PM
  5. are usb 2.0 devices able to work with usb 1.1 hubs?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-28-2004, 08:27 PM
