Results 1 to 10 of 11
Thread: Remote Car Starter
    Newbie strykr's Avatar
    Jul 2006
    Simcoe County, Ontario
    Remote Car Starter
    I got a remote car starter from my job for free, although i had to solder everything together on the board. Umm, just woundering were the best place should be for me to put it? I already know how to set it up, but just woundering where you guys think I should put it? It's the size of a pc mouse.
    Project Strykr
    Car PC - Work Log
    Mar 2006
    Colorado, but Canadian!
    Well most of the connections you will need (constant 12v, switched 12v, start, keysense) all that stuff is under your dash by the sterring column. Easiest place to mount it. Usually a little tuck-away area for that kind of stuff in there too.
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2006
    K, kinda figured that would be a good place to put it. I just installed it about 20 min ago and it works perfectly and I can even use my remote to start my carpc.
    Project Strykr
    Car PC - Work Log
    Mar 2006
    Quote Originally Posted by strykr
    That's why I did it!
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Well I was going to agree with 2k1Toaster on the placement but by the time I submited 2 more posts were made. So now I'll just add, just make sure it's well attached because rattles suck!
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    Jul 2006
    O, im sure nothings going to get it off... Its bolted down in 4 different points and the center.
    Project Strykr
    Car PC - Work Log
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    I was looking into doing something like this my self, but I was thinking of doing it so my pc can start the car by voice, do you guys think this would be a bad idea?
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    May 2006
    Simi Valley, CA
    I'm pretty sure the consensus will be that it's a dumb idea, speaking practically. REALLY dumb if there's no back up. It does have some cool factor though. You would still have to get around the steering wheel lock, if you have one.
    Wait a minute....Just to be clear, you want to remote start your computer then when you get in your car start the ignition by voice? Personally, I don't see the point...
    Jul 2005
    uk
    lol yer some good points there but running head lights and wipers from the pc would be good from voice controll but a different subject
    May 2006
    Simi Valley, CA
    I suppose... just be prepared to repeat yourself a lot. From what I understand there really isn't reliable voice control methods available for the car environment, but then again, I’m a newb…what do I know. Lol Me personally would feel like a goober if I said headlight on and nothing happened, then after like 5 min of troubleshooting I just turned the knob. Good thing my headlights are automatic… why not just get auto headlights? Not sure about the aftermarket availability of those though.
    Okay, I'm rambling... it sucks having a boring job...
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  2. The sickest car alarm - EVER!
    By hd54321 in forum General Hardware Discussion
    Last Post: 06-04-2007, 03:18 AM
  3. FS - Assorted Car Pc Parts
    By OriginalNick2 in forum Classified Archive
    Last Post: 06-23-2006, 07:41 PM
  4. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  5. Keypad car starter
    By lednicazar in forum General Hardware Discussion
    Last Post: 02-15-2004, 12:01 AM
