Originally Posted by
andromedaIVC
I have a solution for virtually controlling your air ride suspension which features these functions:
- Provide logic to move airbags individually or in any combination.
- Airbag movement logic shall utilize feedback from ultrasonic or
pressure sensors to move to the correct height and or pressure settings of the air bag (this is dependent on how efficiently you want to control your suspension). Intermediate positions between min and max should be achievable to a resolution of at least 1/10th the total range of travel, based on the distance from the chassis to the ground surface or pressure in the bag.
- Display the pressure(s) or height(s) in real-time in each airbag and pressure holding tank(s).
- Provide pre-set functions that will automatically adjust the height of the vehicle to low, high, or ride.
- Enable users to create their own batch of commands that will automatically control the vehicle's height based on sequencing (show purposes only).
This is a snippet of what the control application is capable of doing. It has also been incorporated as Digital Mod for StreetDeck as well.
S.T.I.C. Developer
