Results 1 to 2 of 2
Thread: Lobotomized M2-ATX as a POL regulator
    Jun 2005
    Michigan
    Various people (including myself) have reported failures of either the 12V or the 5/3.3V half of the M1/M2-ATX boards. In my case, the 3.3V and 5V seems to be dead, and in my attempt to fix it (on my second board, after sending the first in for warranty), I managed to blow out the PIC microcontroller. Sitting frustrated with a dead PSU, I thought: could I salvage the working half of the board?
    Here's what you do to convert your M2-ATX into a 12V POL regulator:
    Remove the PIC. Just rip it right out.
    If you want the supply to start when IGN goes high: short pins 18 and 15 of the PIC socket.
    If you want the supply to start regardless of IGN: short pins 14 and 15 of the PIC socket.
    If you want to start the supply using any random 5V source: connect the 5V directly to pin 15.
    It will be similar for the 5V, but I cannot test that given that mine doesnt work. Im currently using this to power my Lilliput. Works like a charm.
    Only issue: you need a clean IGN source since its now directly connected to the MOSFETS. If IGN sits somewhere between 0 and 12, you may get weird things happening on your output...
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
    Newbie gasse's Avatar
    Sep 2006
    Italy
    Clean IGN source?
    IGN between 0 to 12... what's the problem? I don't understand.
    LPG powered FIAT Stilo 1.8 16v - carputing the road since 2005
    AMD Athlon64 3200+, Asrock K8NF6G-VSTA, 1x512Mb DDR Geil, 1xHdd Maxtor Momentus 320Gb, LG GH22NS DVD burner, M4-ATX, Delong 7" monitor + TS @ 800x600 75Hz, backup camera, ELM327
  1. M2 ATX - EN15000 - USB - Problems!
    By BulleDK in forum Power Supplies
    Last Post: 12-28-2006, 04:29 PM
  2. M2 ATX Manual
    By lanman1 in forum Power Supplies
    Last Post: 08-16-2006, 02:28 PM
  3. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  4. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
  5. wtb: 12v regulator and opus pol ps
    By EsKALad in forum Classified Archive
    Last Post: 10-25-2005, 01:57 AM
