looks good![]()
Hi All,
For a good period of time, the HQCT-Modules were only available in europe to people who pre-ordered beforehand.
Due to the success of the module, we've had to close the pre-ordering so we wouldn't get too far behind.
BUT
From the 27th of october on, the HQCT-i module will be available to everyone.
For the moment, we have only the HQCT-i (the smallest version, designed to be built into the CarPC case or your own housing) available.
Within the next weeks/months 2 other models will become available:
- The HQCT-e, with the same funtionality as the HQCT-i, but in a nice metal housing, using external connectors for USB, audio, power and antenna. Ideal for less technical people, everyone that uses a laptop or people who want to use an external model for any other reason. Pricing will be around 125 euro.
- The HQCT-eA, also an external model, with built-in 4x50W amplifier which eliminates the need for amplifiers if you want to completely replace your Car Radio / Headunit.
All models have AM/FM with RDS.
Basic functionality is supported by RoadRunner and CentraFuse.
Soon there will be a touchscreen-friendly version of a stand-alone application that can be integrated/embedded into all other front-ends.
So, from 10/27 on, be sure to order your HQCT on http://direct.xtronic.be
Regards,
Joachim
http://www.xtronic.be
looks good![]()
Any chance of a version with digital output? or audio over USB?
Looks good tho. if it was available in the models above I'd have ordered mine ages ago![]()
Awesome.
FM and AM will be nice.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
You selling Blinds NOW :-)
P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
Oops, website had a glitch
Solved!
