Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Poor man's guide to remove power supply noise from audio
  1. #11
    Gip
    Gip is offline
    Jan 2005
    Quote Originally Posted by Ruffy View Post
    I have spare modems, many of them. Most people that have build computers through the years have at least one.
    I also I have RCA jacks and mini 1/8" plugs, same thing as above.
    With alittle knowledge of the tools anyone can make it in like 10 minutes or less. I know I could.
    A Premade one can be bought for under $20. But wheres the thrill of making something yourself with that?
    Hell you can buy those transformers for $2-5 each and make your own for under $10
    Well, I must admit it, this tutorial is mainly for people like you (and me), who have tons of "junkies" too hard to throw away because "you never know..."!
    And I must ABSOLUTELY quote "A Premade one can be bought for under $20. But wheres the thrill of making something yourself with that?"!!! Are we the same person?
    Btw, I'm not really a "poor man", and I don't think that everyone having enough money and effort to spend in a carputer is a REAL poor man, but I simply LOVE the challenge of efficiency. I always want to obtain the best results with the smallest effort... And I succeed most of the time! Sorry for you guys that prefer to buy premade things, paying more and learning nothing, but I'm a geek and I'm proud of it! Well, actually I'm not a real geek, since I have a girlfriend, but who cares!
    PS: my circuit is wrapped up in 19 cent red electrical tape...
  2. #12
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by Gip View Post
    Some of us are geeks that already know how stuff works, and recognise that sometimes the most efficient way to get stuff done is to buy a mass produced device.
    I'm surprised you didn't wind your own transformers...!
  3. #13
    Gip
    Gip is offline
    Jan 2005
    Quote Originally Posted by Rob Withey View Post
    Touche... But what about the satiafaction! Btw, I myself already know how and why this stuff works, you surely can imagine that I haven't tried to put every single component of a modem pc board in series of the audio cable to find out tha the transformer works better!
    You will be surprised to know that in the past i even wond (mmmh... past of "to wind"? sorry for my english.....) my own transormers...
  4. #14
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    wound. You were on the right track with the word. The English language is not friendly.
  5. #15
    Variable Bitrate miwise's Avatar
    Sep 2006
    worked nicely for me. I already had a ground loop isolator (from radio shack) b/w the computer and both amps, but I was getting a loop b/w the sub amp and highs amp. I installed this b/w the 2 amps. Worked great!
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
  6. #16
    Sep 2006
    I had tons of problems with the generator noise, and had tried a lot of stuff (but apparently gone in the wrong direction). Then finally turning to the net (where I of course should have started) I found this, which works perfectly! Thanks a million man!
  7. #17
    Dec 2005
    Naples, Florida
    Arg! I just threw away two modems I had kept for the longest time. I have tons of parts that I finally decided to organize and consolidate. The only stuff I chucked were the modems and an 8MB graphics card. I should have known better. I like your tutorial and would have preferred to build the isolator over junking the parts. Never fails when you decide to chuck something
  8. #18
    _
    Mar 2004
    Little Elm, Texas
    Induced noise/Ground loop trouble shooting guide.
    some of you should venture into the Car Audio forum more often...
    Jan Bennett
  9. #19
    Jul 2005
    sorry to disagree with the solution.
    telephone/modem coupling tranformers are good only for telephony,
    that mean they are made for telephony bandwidth : 300-4000Hz
    below and above this range, nothing is guaranted and the cheaper the device, the narrower its frequency response.
    Did you measure 20Khz and 20Hz output levels compared to a reference @ 1KHz ?
  10. #20
    Jul 2005
    I might be making a big assumption but I would have thought that the interference noise had a relationship to the RPM of the engine, in which case the telephony bandwidth is almost perfect - I guess it could go a little higher
    Spuzzdawg
  1. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  2. Power Supply
    By MrGee in forum Newbie
    Last Post: 06-21-2006, 05:44 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
