Don't know how I forgot it worked by isolating the grounds by the time I got to the end of the thread - thanks for correcting me. A lil OT Rob Withey but how did you get the neat little pop up table for your car specs?
Spuzzdawg
The transformers don't filter out the noise. They isolate the grounds.
If it was a case of filtering, a simple high pass RC filter would do the trick.
Spuzzdawg
Spuzzdawg -
http://www.mp3car.com/vbulletin/announcements/93477-carpc-specs-in-the-user-profile.html#post987518
In the forum announcements.
Jan Bennett
I just grounded my motherboard to the chasis of the car...and it was gone
BossTone74
Transformer limited bandwidth means bass end treble will be substracted from your music, this by no means is expected![]()
Thanks, will try this![]()
well, i had the same problem with my car pc. i just added a ferrite ring on the RC cable. gave about 3 -4 round around the ring. and the ferrite ring is for about 0.5 usd i think.
very impressive that you can build your own.
but a good working GLI is 15 bucks at circuit city made by Tsunami in the car audio section, and it's more durable so I don't have to worry when I shoved it behind my dash.
How about this for a poor mans solution to interence??
I bougth a USB creative soundblaster Live, works great etc. But if my phone is near it, with the sound high, it can get alot of interference. So I started experimenting.
I chucked it into a large anti-static bag and hey presto, approx 50% of mobile phone interference gone!
Plastic is not the best thing to wrap things up in and besides, 50% is still quite annoying!
So I wrapped it up in foil.....normal everyday kitchen aluminium foil. Worked a treat, by my reckoning, approx 95% of inteference gone!!
I am willing to bet if I put two layers and grounded the foil, I could possibly get 99% if not possibly 100%??
If it works for mobile phone inteference, could possibly work for other types of inteference??
Since this is a cheap simple way of cutting inteference, maybe someone could put it to use and let us know??
Also, why stop at the sound card? Why not enclose the PSU and/or computer in this manner??
The only problem I can see, with it being aluminium, it conducts electricty, so you have to be VERY careful not to short anything out!
Also could be a tricky issue with vents etc??
