This is simply a ground loop isolator.
Intro
Well... You just connected your notebook to a car power adapter and to the amplifiers... But... WTF! You hear a very loud buzz from the speakers, and you can barely hear the music playing on your PC! Please, help me Mastro Gippo!
Example of a noisy environment:
Car -> DC-DC Inverter, 12V to 19V -> Laptop -> 3.5mm Jack to RCA cable -> Amplifiers
Here is the solution!
What you need:
-2 old modems (56K or lower, with the little transformer)
(get them from your nearest dumpster)
-the 3.5mm Jack to RCA cable (or whatever connector you need)
-soldering iron and standard stuff
-optional but recommended: a proto-board
Before you start
Standard disclaimer: I'm not responsible if you break your stuff or die. This method works for me and for that kind of noise. It won't eliminate any other kind of noise. Please do this only if you know what you are doing, and ask help to someone that knows electronic better if you are in doubt.
Let's go!
Carefully remove the tranformers from the modem PCB using the soldering iron (heat one pin and gently pull the transformer, then heat another pin, then another, then the last, repeat until the transformer falls into your hand - warning, hot pins!). Beware, these transformers are very fragile and you can break a pin if you pull out too heavy!
Now you should have two transformers, just test them to check if they work using an ohmeter.
The windings should have an impedance (resistance...) of 150ohm.
Cut the adapter cable in half, or at the point that suits you best, strip a bit of wire out of the ends and pre-solder them.
Solder the transformers on the proto-board, then solder the cables following this schematic:
I'm not so good at paint, so I added 2 pictures of the finished product so you can get an idea of the circuit. The white wire is only for holding the other two wires,so I don't break them if I pull too hard.
The end!
Connect the cale between the PC and the amplifiers... And it's done! Total cost: about 10$.... (even less if you already have the two modems, or if you find them for nothing).
And the quality??
This circit will not add any interference/distortion to your signal. You may have some impedance issues (the signal should increase a bit in amplitude) but the output will be 99.999999% the same as the input.
I hope you apprecate this topic and maybe make it sticky... I'm very busy at wok, but I will try to give support to anyone who needs help.
Bye
Gip
interesting
if i have induced noise i'll try it
considering i bought my ground loop isolator for 12 euros then this is a veeeeery poor man's groung loop isolator
but nice to read how to do it and have fun to make![]()
That is called "a poor man, 2 spare modems, other bits and alot of time" solution.
I think the poor man with no spare modems would just buy the premade one
Nice tutorial though![]()
I have spare modems, many of them. Most people that have build computers through the years have at least one.
I also I have RCA jacks and mini 1/8" plugs, same thing as above.
With alittle knowledge of the tools anyone can make it in like 10 minutes or less. I know I could.
A Premade one can be bought for under $20. But wheres the thrill of making something yourself with that?
Hell you can buy those transformers for $2-5 each and make your own for under $10
transformer
http://www.allelectronics.com/cgi-bi...:600_OHM_.html
$1.00 x 2
or
http://www.allelectronics.com/cgi-bi..._600_OHM_.html
$1.00 x 2
http://www.allelectronics.com/cgi-bi...CA_JACKS_.html
$1.25
http://www.allelectronics.com/cgi-bi...RF_BOARD_.html
$0.75
+ shipping = $11.00
At those prices you might as well buy extra parts and make several of them to make up for the high cost of shipping
Cool
How about a nice project box + gromets for the board to finish it off?
