First off, this site has TONS of info- try searching next time, it helps keep the clutter to a minimum.
But, the easiest way to find which connect to turn on the laptop is to use a multimeter across the terminals until you find the pair that closes the circuit. I would recommend unplugging the laptop and taking out the battery. Just look for continuity.
LinkBack URL
About LinkBacks
