Page 20 of 25 FirstFirst ... 10111213141516171819202122232425 LastLast
Results 191 to 200 of 244
Thread: Someone here has be be able to crack this HDRadio for the car!
  1. #191
    Low Bitrate rcubed3r's Avatar
    Feb 2007
    Salisbury, NC
    Quote Originally Posted by CaliM5 View Post
    Is there a way I can hook everything up outside of the car? I want to test it before everything goes in. Currently have everything running on my desk. Someone post a write up on wiring please. Thanks.
    See post #170 and 172 in this thread.
    I ran it on my bench for a couple of days before putting it in my car.
    Ron
  2. #192
    Apr 2007
    Hi, can someone help me with this please. Can I connect the audio output from an HD Dice to the AUX in on a head unit or aftermarket processor with adjustable sensitivity and 10k Ohm Input Impedance.
    Jun 2006
    Milton
    Quote Originally Posted by xtremak View Post
    I just figured out the connections for a BMW just connect everything as you would. The IBUS adapter connected to the PC, connected to the IBUS in the car. The DICE unit connected to the IBUS in the car. I will post a simple diagram showing this.
    Thanks for the reply xtremak - any chance of a picture showing the connections the way you have them in your BMW? I am using the CD IBUS connector to the eedesigns IBUS interface rather than Rolf's, but I assume this shouldn't make any difference?
  4. #194
    Sep 2005
    Quote Originally Posted by drewgt2 View Post
    I will try to get a picture tomorrow. Basically just tap into the wires from the 3-pin connector and run them to the IBUS interface, creating a parallel IBUS connection. This way you can use the headunit if you still have it in the car to control the dice unit along with the software.
    I have not used the eedesign's IBUS interface but assuming its similar it should work no probs. Just make sure the CTS line on the serial port works as the software uses this to provide collision detection between IBUS packets.
  5. #195
    Feb 2007
    Salisbury, NC
    any updates?
    mine is working fairly well...no nasty issues.
    Ron
  6. #196
    Sep 2005
    Alright guys hopefully will have an update out this weekend which will add the options of opening the com port automatically on startup, ability to have the software start minimized and also BMW specific options to control RR from the BMW steering buttons.
    I am glad to hear that there are no nasty issues with the software so far. Please post your feature request so that I can add them in. Once the software becomes more user friendly, I will open it up and start writing VB code (will try and work with guino) so this can added into RR as that is my frontend of choice.
  7. #197
    Sep 2005
    I will be mailing out the next beta release to all the people on the beta list later tonight. All your contributions are greatly appreciated.
  8. #198
    Feb 2007
    Richmond Virginia
    I finally installed my dice unit and hooked it up to my factory ant. The reception is very poor. I'm not in a HD area so I can't test the HD but my reception for regular fm is very poor. I used an smb to motorola adapter and Motorola to Chrysler. I only get 2 channels with static. I tried a different adapter that I made and no differance. If I unplug I get nothing. Any suggestions?
  9. #199
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    This has been the problem with this project, no movement, seems like an extortion racket, well not quite, but just doesn't feel right with no updates for a few weeks.
    My only request is support for RR, with all the features the hardware supports (aux audio input and iPod support)
    Sorry to rant, as a token I'll be contributing in a larger manner, aka hardware wise, very soon.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  10. #200
    Feb 2007
    Salisbury, NC
    Quote Originally Posted by YellowMater View Post
    I tried a lot of different ways to hook up mine to my factory antenna. The best method I found was using the Dice antenna before connecting to the car antenna. In other words, attach the Dice antenna (without the tape pigtail thing) to the unit, and then attach that to the car's antenna. The Dice antenna has a ground strap you'll use, and where the screw goes thru the little box is the other connection you'll need.
    Ron
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 07:34 AM
  2. In a real PC car struggle
    By markland556 in forum Off Topic
    Last Post: 06-27-2007, 11:36 AM
  3. Replies: 9
    Last Post: 06-08-2006, 05:15 PM
  4. Employee Discounted Cars: Flatout BIG LIE!
    By sdashiki in forum Off Topic
    Last Post: 10-31-2005, 05:53 PM
  5. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 12:42 PM
