Page 21 of 25 FirstFirst ... 111213141516171819202122232425 LastLast
Results 201 to 210 of 244
Thread: Someone here has be be able to crack this HDRadio for the car!
  1. #201
    Mar 2004
    New Jersey
    Thumbs up
    Quote Originally Posted by DaveDog View Post
    This has been the problem with this project, no movement, seems like an extortion racket, well not quite, but just doesn't feel right with no updates for a few weeks.
    My only request is support for RR, with all the features the hardware supports (aux audio input and iPod support)
    Sorry to rant, as a token I'll be contributing in a larger manner, aka hardware wise, very soon.
    DD
    Xtremak is still working on the software. Remember he was has only had his own unit for a short time, and I not being a programmer was only able to put the 3 devices together to see if they will work in the beginning. The beta software is out there and im sure X wants the software to work flawlessley. I have a wedding to finish planning in the next 60 days so i havent been around to test much of the software.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
  2. #202
    Mar 2004
    New Jersey
    Quote Originally Posted by YellowMater View Post
    I finally installed my dice unit and hooked it up to my factory ant. The reception is very poor. I'm not in a HD area so I can't test the HD but my reception for regular fm is very poor. I used an smb to motorola adapter and Motorola to Chrysler. I only get 2 channels with static. I tried a different adapter that I made and no differance. If I unplug I get nothing. Any suggestions?
    I think the issue may be the multitude of adapters. Also, do you know of your radio uses an amplified antenna? My Chrysler had a power lead going to a box that my antenna hooked it up to. It had no reception until i gave it power. The DICE anteanna worked alright for me but it wasnt until i hooked it up to my stock 300C antenna that i got all my stations and even a bunch of HD.
    -Jack
  3. #203
    Sep 2005
    Davedog I can understand your frustration, but at the same time you have to realize that I am not working full time on developing the software for the unit, I do have a full time job and a life outside of all of this. Also, I do not want to release something to the community which does not work flawlessly.
    In case any of the contributors are not happy with the progress please let me know and I will return your money. I did not start this to make money, I did this to get a decent radio solution in my car.
    Also, if overall people feel that there is no progress being made, I am going to stop work on this project and just keep it to myself. No point in dissappointing people.
    The software was written to be very generic and at the moment one can use all of the features of the dice unit exactly as stated in the DICE manual.
    eg: If you were to press 5 then go back to hit < to go to CD 05-01 you would get the IPOD to work.
    The IPOD / AUX / AM / FM buttons do not work as I am yet to figure out the right combinations of commands / responses to send to the unit all at once when the buttons are pressed.
  4. #204
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Don't take my comments as a guage for what the community is thinking. I was just frustrated.
    Looks like you have things progressing, an occasional update would be nice.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  5. #205
    Feb 2007
    Richmond Virginia
    I am in a larger radio market this week. I'm getting more stations but I have not had time to look for an ant amp. I'm also having issues with my soundblaster x-fi extreme gamer pci card. Sometimes when I hit play in the alpha version all I get is a pop from my speakers and other times I get sound. I'm running my dice and Ibus adapter from my 12v rail. Should I try an unregulated 12v source? It seems the creative software is an issue somewhat but reception is not what I had expected. I will try to see if my original unit had an ant amp but I doubt it did as a near base factory head unit was in this truck.
  6. #206
    Low Bitrate rcubed3r's Avatar
    Feb 2007
    Salisbury, NC
    Quote Originally Posted by xtremak View Post
    I don't know how you guys do this at all. The only way I even got my carputer put together was because I was out of work for a few weeks due to foot/ankle surgery.
    Keep up the good work!
    I, for one, appreciate it greatly!
    Ron
  7. #207
    Feb 2007
    Richmond Virginia
    I agree with rcubed3r.
  8. #208
    Mar 2004
    New Jersey
    This is somewhat of an anomoly. Its the timing of the Ibus unit itself. When i had the IBUS software running i had to send the init command 2-3 times for it to initialize, you will hear pop then a hiss then it will kick in. Ive been looking at my HEX dumps from the unit to see what exactly happens when it powers up. Im running an unregulated source to my unit, i figure that since it was made for the car you dont need to give it stable 12 voltage. Also, do you have a window antenna or do you have a real Arial wick.
    -Jack
  9. #209
    Feb 2007
    Richmond Virginia
    I have a real arial wick. If I don't have an amp I may add one.
  10. #210
    Feb 2007
    Richmond Virginia
    Does anyone know what type of connector the chrysler uses after 2002? I know the Dice uses an SMB. And many cars use Motorola but I would like to make my own with either my own crimp or solder on connections and not have to use two adapters or splice the cable. I cut off the Dice antenna connector and soldered it to a Chrysler adapter. The reception is the same as using 2 adapters. I do not like it because the center wire on the dice is so small.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 07:34 AM
  2. In a real PC car struggle
    By markland556 in forum Off Topic
    Last Post: 06-27-2007, 11:36 AM
  3. Replies: 9
    Last Post: 06-08-2006, 05:15 PM
  4. Employee Discounted Cars: Flatout BIG LIE!
    By sdashiki in forum Off Topic
    Last Post: 10-31-2005, 05:53 PM
  5. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 12:42 PM
