Page 5 of 25 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 244
Thread: Someone here has be be able to crack this HDRadio for the car!
  1. #41
    Mar 2004
    New Jersey
    Quote Originally Posted by DaveDog View Post
    Ok the other IC on the main PCB is a BD3805F , that is a 4 channel audio controller, must be a switcher for the iPod interface, it's controlled via a I2C bus, so what do you wanna bet the communication between the car interface PCB and the main PCB is also I2C ?
    VERY INTERESTING.. do i also smell Optical out?
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
  2. #42
    Mar 2004
    New Jersey
    Kamakazie2
    Should be get this thread moved to hardware development? Seems like that's where it really belongs.
    I agree.. i will put in a request
    updated 1st post
    -Jack
  3. #43
    Elsewhere
    Kamakazie2
    Done.
    How about the Wiki?
  4. #44
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Quote Originally Posted by Kamakazie2 View Post
    I was thinking the exact same thing!
    Were all set to go, just waiting now for the ibus adapter to get here.
    I found out how to get the ibus working without the ibus. I spoke with the guys on hackthe ibus and they confirmed the hook up goes like this:
    12v pin: Give 12v+ to the Ibus interface and the DICE unit
    Ibus pin: Give 12v+ with 1kohm resistor to the Ibus and DICE unit
    Gnd: Ground to both Ibus interface and DICE unit
    http://www.mp3car.com/vbulletin/show...6&postcount=86
    found that post
  5. #45
    Mar 2004
    New Jersey
    Quote Originally Posted by sama View Post
    much appreciated.. I just looked at my cdrom cable and I have 4 independent wires.. however I will doublecheck. that would have been horrible!
    -Jack
  6. #46
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I wouldn't worry too much, the car is very reslient...
    I had a short on a circuit for the ibus lines, and it was fine. I took it off right away though.
    I even once put the battery terminals the wrong way around once, after checking it 3 times... I don't knwo what happened to me, I think I took too much medicine or something. Anyway, I got off lightly with only the FM antenna amplifier blowing up.
  7. #47
    Mar 2004
    New Jersey
    Just try explaining that to your dealer..
    My Blinkers, windows, a/c, radio, and cd changer dont work...
    -Jack
  8. #48
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    chatted with mitch
    Had a chat with mitchjs last night, basically asking him if it was worth going down the path of decoding the I2C bus to perhaps eliminate the need for the ibus/usb converter, and having a I2C/USB direct interface. He thought the cost wouldn't be much less and that the path we are currently following will be the easiest.
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
  9. #49
    Mar 2004
    New Jersey
    Yeah he PMd me last night. I think that we are good the way we have done it
    1. We have a stable interface
    2. Its has Roadrunner support
    3. Its possible that we might be able to add other devices on later
    -Jack
  10. #50
    Mar 2004
    New Jersey
    Ibus has arrived!!! The build starts in the morning..
    -Jack
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. In a real PC car struggle
    By markland556 in forum Off Topic
    Last Post: 06-27-2007, 12:36 PM
  3. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  4. Employee Discounted Cars: Flatout BIG LIE!
    By sdashiki in forum Off Topic
    Last Post: 10-31-2005, 06:53 PM
  5. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
